Honestly, I'm surprised it took them this long to get only this far. I mean, modchips for the original xbox were released in like less than a month, right? Heck, XP was cracked before it even came out!Captain Newbie said:That took...three weeks
Don't think it will be that easy, Microsoft has learned from their previous XB1 security blunder - and this time they do not even trust data running on the internal hardware bus.
Executable data is hashed and signed using asymmetrical keys built into the different hardware components (gpu, cpu etc). As each console has different keys "burned in", compromising one machine will mean nothing for the others!
Even if you use your electron microscope to compromise the keys of all your hardware components, using normal "man in the middle" code-injection (as mod-chips usually do) will be hard.
So there you have it ... Unless they have screwed up completely by leaving keys readable - this might actually be the first non-hackable console.
That doesn't prevent piracy of course, Chinese Entrepreneurs will line up to duplicate optical copies in about 3 seconds
I completely disagree, they now understand that the 360 file system resembles the Xbox's, so there's no reason that crackers can't work using the same techniques they used on the Xbox. In addition, the Gamecube never had a hard drive, and only Nintendo had rights over the tiny discs. The 360 will be cracked because it uses a standard sized disc that pirates will be able to duplicate, and it has a hard drive which makes it easy to download ISOs or whatever.AC Slater said:The 360 won't be really cracked for a long time. I have a feeling that it will be like the Gamecube.
LoneWolf121188 said:Honestly, I'm surprised it took them this long to get only this far. I mean, modchips for the original xbox were released in like less than a month, right? Heck, XP was cracked before it even came out!
Question: if the raw data can be extracted, can't they then make exact copies of the disks, essentially bypassing the copy protection?
i give it 6 months.SuperFarStucker said:I'm going to wager that nobody will ever get the xbox 360 to run unsigned code if even half of the protection features that are thought to exist actually do. As for piracy the simplest way would to get discs that are identical to the x360 discs, I realize they are just dvds but obviously any old dvd+r isn't going to work.
Vrykyl said:the gamecube never realy had any succesful piracy - the unique disks and non pc compatible media protection pretty much stopped all piracy on the system
=ACID RAIN= said:I guess my question is, does the 360 have a way to determine if a disk is authentic or not, if the disk is an exact copy of a retail disk? I don't know because I don't do console gaming
