XBOX 360 question
Lionsault_100
Did my share of googling and I can't find a clear answer -
Is it possible to put any sata hard drive into an xbox360 ?
and if so would i be able to put it in internally ?
You CAN hook any SATA drive up to a 360, BUT it requres a special adapter and a fair amount of fannagelling to do it. People have replaced the 20GB drive with 100GB 2.5" notebook drive by replacing the drive in the enclosure that clips onto the side of the 360 as there is no room for one internally. It's not worth it IMO. If you're looking to skimp on the price of the 360 by getting the core unit, I'd advise against it beause it's worth the extra $100 for the wireless controller, headset and hard drive. If you're just looking to upgrade the drive for more storage space, then you can use ANY USB 2.0 hard drive. It will let you save anything on it BUT LIVE content. You can store music, movies and game saves there. You can store LIVE content to it as well but will have to copy it back to the 20GB drive to play it.
Lionsault_100 said:
thanks for this very clear reply, i guess i'll just look for a premium
If you're relatively close to a MicroCenter store, there is a $100 rebate there. I have a link to the form over in Cyber Deals section.
I actually received that circular, someone had a used core system on CL without rebates for $200 with 2 controllers, but its a waste of time if i cant add my own hdd, i see premium systems for $300 anyway
