So here we go again. I just moved and reconfigured my router. I have a D-Link Gamefuel router, I believe the 4500 is the number associated with it. Laptops are working great, PS3 working great, room mates Iphone connects with no problem. Xbox Live, just screwing with my head. Hopefully someone here can help because I can't stand Xbox support, they don't have answers just circular questions.
On this network:
3 Laptops
1 PS3
2 Xbox 360
Both xbox 360s have the same issue with xbox live right now. 1 is wired and the other is wireless. Both have current gold supscriptions. The will connect and then drop connection. I can test live connection and it will fail only to pass 2 minutes later and then fail at account login or work until you turn on the game and then disconnect. Very random in the failure timing. Every failure is at xbox live. It always passes connecting to the router and internet. Both systems are open NAT. I tried shutting everything down and rebooting starting with the modem. I have tried assigning a static IP address to both xboxs and opening the corresponding tcp(80, 3074, 53) and udp (88, 3074, 53) ports only to find the same issues. Anyone have any suggestions? Thanks.
On this network:
3 Laptops
1 PS3
2 Xbox 360
