Hi, this is my first post, hopefully I'm posting here the proper way.
I have 2x E5 2665 v1 with Noctua U12DX-i4
After turning on the PC it idles at 35-45 (coolest / hottest core), but slowly goes up to 39/49C
Room temp is 26C and I noticed that my GTX580 is running at full clock all the time (52C at idle). I'm using a high-res display, at lower resolutions the GPU downclocks itself but not at 3440x1440. I'm getting a new GPU soon anyway, do you think that will solve the problem?
Summer + GPU heating up the case is enough reason to run this hot? I did not dare running prime95 at this state, but during Cinebench the maximum temps are 56-65C (depending on core).
Fan is only at 500 rpm, but that should be enough for idle imo.
Pretty much any kind of help / advice would be much appreciated.
Update: I cranked up the CPU fan, idle is unchanged, Cinebench is 52-61C now (max temp, not average).
