- Aug 20, 2001
- Oshkosh,WI
I would like to try and figure out what I've changed or havent changed on my systems to get such a high lag.If I'm lucky i get 12XX or else its even higher yet.I thought maybe I was just soo far away from a server,so I set it up to run as a dedicated server on another system I have.no luck,very high pings for me,even on a lan connection.Then I thought ok,bad cable,loose connection,ect.Cant find anything wrong.My UT2003 server I set up get's in the teens for a ping and my buddies in the area all get in the 60's. I run XP Pro on my systems-updated,I have a cable connection(buisness class),I use a D-Link Router Model DI-804HV,and also a D-Link switch DES-1024D.
I have been working on this all day and my head is spinning,any ideas would be most welcome!
