Xp 1800+ Jiuhb = Xp 1700+ Jiuhb????
Koenraad
Belgium
Are these two ( XP 1800+ JIUHB and XP 1700+ JIUHB) from the same batch ( maybe even wafer) because they have the same stepping? Would it make any difference in howfar i can oc them?
or in other words would i get the same speed out of the 1800 then i would get out of the 1700?
demon-eater
Central Pa
correct me if im wrong guys but isn't JIUHB the core revision you need to tell the line below that for instance
JIUHB
AROIA0311 (sorry coun't think of any other stepping)
K
Koenraad
Belgium
JIUHB
JIUHB is like AROIA.
if you read this tread http://forum.oc-forums.com/vb/showthread.php?s=&threadid=127682
it say that JIUHB is the batch they are all made of. so i was guessing that you could have an 1800 and an 1700 from the same batch
