XP 1800+ on KR7A-133 RAID.
Aspect404
Cheyenne, WY
Hey guys, I posted a while back about my ASUS a7a266 being fried from my water block. Well I got the new Kr7a-133 Raid, and Im VERY pleased. On stock voltage and everything I merely jumped the bus to 145 and Im registering an XP 2000+ at 1.67 Ghz. My CPU benchmark is 4704 MIPS and 2318 MFLOPS. Just thought that I would let you know that this is one Kick @$$ board and chip combo. Thanks for all the suggestions in my last thread
Milkman
NH Biodiesel master
Thats exactly the same combo I have and with a volt mod and good cooling I am @ 1792 stable with my Xp unlocked, very stable running prime95 and everything else, max temps I have seen are 45c under full load with heat on in the house:D
phiber
Senior Member
Queens, NY
are you using grabbers for your vcore mod? i cant really get a grabber to stay ther cuz the vid card bothers it
btw im running at 150 FSb with a 1800+ that makes 1730...def voltage
Milkman
NH Biodiesel master
Gotta fire up the cam, but it sorta just lays across the vid card at a slight angle, I did zip tie it but that seemed to wanna pull it off so I removed the zip
