- Oct 10, 2002
- mAgg0t fArm
Hi guyz, my first post, so first of all, hey
Ok, well, here it is. I just got my new setup. It consists of the following:-
2000+ XP Agoia
256mbx2 Crucial 2100 (from old system, getting 3200 soon)
Epox 8kha+ with latest bios
SLK-800 with Mectronics 54cfm 80mm (loads of 40c running at 2200+ speeds)
Ok, so ym problem is as follows. Im currently running at 149 FSB, and its stable in prime 95 etc, although memory intensive stuff, typically games, crash sometimes (not hard lock, just desktop crash). My first presumption was the memory as i can get past 150FSB and run prime 95 fine. Now the reason im not running at 150FSB (apart from crashes) is that i've noticed something quite bizarre, and need some help.
At 149FSB i get loads of 42c and sisoft benchies of roughly 2200/2100, about right im told.
At 150FSB my memory gears down to pc1600 and im only getting 1600/1500 in sisoft.
I'm not changing anything bar the FSB, and its only occuring at 150+.
My brother suggested it maybe, although unlikely, a voltage issue. So i'm now running at 1.85vcore and 2.8vdimm, yet the problem persists. Could this be the memory? And is there a resolution other than buying higher rated chips (run out of money atm hehe
I assume its the memory as people always getting way over 180 on this MB, so i doubt its the MB, the chip is running all teh cpu tests flawlessly at 150+ FSB (ignoring that i have mem issues), so im guessing the crashes in games + low bandwidth = memory, as obviously the cpu tests barely touch the memory so they pass.
Thx for any help u can give
dAs_mAgg0t
2000+ XP Agoia
dAs_mAgg0t
