No, it's most definitely
not pointless, Lawsy, nor are the performance increases minimal or meaningless.
Let's put it this way. I have a chip that will do 2.4ghz on air with 100% stability. However, I have ram that can only do 166mhz on 5-2-2-2 latency timings. Now, at the current point in time, 12.5x is my highest multiplier. What's the cpu frequency I'm operating at? It's 2.08ghz. That's a huge difference from 2.47ghz (which this chip has done with a friend's ram), or even 2.4ghz.
So, if we were able to increase the multiplier, from 12.5x to, say, 14.5x or even 15x, we'd get the majority of the benefit of an additional 400mhz, although the increase in performance wouldn't be as much as increasing the fsb to 224mhz while running 11x multiplier, of course, but performance would STILL noticeably increase! Also, with an AMD chip, even with the nForce 2 chipset, the additional ram bandwidth is only 1/2 of the equation in determining the performance increase, at best.
Regardless, a higher clock speed WILL increase performance for me in a measurable, noticeable way in windows, gaming, and video encoding.
For your reference, search for a post in this AMD CPUs forum where a guy tests different fsbs and multipliers all resulting in the same actual clockspeed. Note the performance increases (or decreases, in one particular instance).
Also note that non-resonant frequencies result in less performance increase than multiples of the 33mhz pci bus (133,166,200,233, etc.), although they typically still increase performance.
So, since I cannot afford better ram, at the moment a solution to increase the multiplier would be the only possible thing to increase my pc's speed. There you have it, bro.
How's the foot taste? Properly spiced?
Just kidding, dood.
Methusela
