XP 333R NO USB ports work at all???
jgaud
NEW HAMPSHIRE
Im I missing something here??? did all the drivers etc. couldnt find any USB specific divers to DL. and no one else seem to have this prob ( yes I tried the external set on the board too??) with multiple functioning devices???? PLEASE HELP I hope I am stupid I dont wanna RMA......Sigh oh yeah WIN XP could that be the problem???
redduc900
Inactive Moderator
Portland, OR
I'm not quite sure about the XP-333/R boards (AFA Iwill disabling USB "by default" in the BIOS)...but that's the way it was with the KK266/R boards. If you haven't already, I would check under the "Advanced Chipset Features" of the BIOS and make sure that the "OnChip USB Port/s" are enabled (USB 0 is for the built-in USB Hub, USB 1 relates to the 9-pin connector in the lower RH corner of the board for connecting a 9-pin riser kit)...which wasn't originally included with the KK266/R boards, and had to be purchased separately.
BTW, "USB Keyboard Under DOS" in the BIOS was normally disabled by default also.;)
