- Jul 6, 2002
- Good old UK
I have looked briefly at posts here on the 9700 and knew there were problems before I bought one. Like many other people, I suspect, I was seduced by promises of framerates and features.
So, now I have a Hercules Radeon 9700pro. Installed the drivers off the driver disk under windows XP, rebooted, yada yada. Ran 3Dmark2001 (not SE) to see what it could do. It shut my computer down. Ok, so i thought, driver issues, went over to the ATI site, got catalyst 2.3 drivers and re-installed. No joy. It will run some tests ok, but nature for example, locks up and shuts down my pc in the first scene. I've just got catalyst 2.4 and RE-INSTALLED windowsXP, put the drivers on, and still no joy.
My system specs are:
dual athlonMP 2000's
Asus A7M266-D
1GB ECC DDR ram
2 IBM 40GB HDD's
soundblaster live
usb2.0 card
530watt PSU.
There's nothing else I can think of that could be having this problem. Is it a dual CPU thing? I know some software doesn't like it, but they've been alot better generally under XP - not so "clunky" as W2K. The last thing I'm going to do is go back to windows2000 and see if that fixes it. Any ideas you chaps/chap-esses have would be smashing
Thanks.
Asus A7M266-D
1GB ECC DDR ram
2 IBM 40GB HDD's
soundblaster live
usb2.0 card
530watt PSU.
