When you try to start or restart your Windows XP-based computer, you may receive one of the following error messages:
- Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
- Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
- Stop: c0000218 {Registry File Failure} The registry cannot load the hive (file): \SystemRoot\System32\Config\SOFTWARE or its log or alternate
The procedure described in this article uses Recovery Console, System Restore, and lists all the required steps in specific order to ensure that the process completes fully. After you complete this procedure, the system should return to a state very close to the system before the problem occurred. If you have ever run NTBackup and completed a system state backup, you do not have to follow the procedures in parts two and three; you can skip to part four.
