XP1600+ Unlocked Multi
markodude
Europe
Hi peeps
DOes anyone have the 8.5x Multi working on above chip?
I can get 8x205FSB or 9x190, Cant get 8.5x multi for highest FSB/PRocessor speed combo. Is the 8.5 not available on XP chips?
P.S
Getting one of first AXP2400+ in stock in UK hopefully tomorrow. Benchies coming soon, Im hoping for around 200x11 to get 2200mhz and DDR400 speeds. Should be kickass!
Arkaine23
Captain Random Senior Evil
XP's
8.5x on both a 1600+ and 1800+. If the x.5 multi's don't work, its often the 1st L1 bridge that needs to be redone.
markodude
markodude
Europe
IC - Ill have a look at L1, my job was a bit bodged! I found that the rear window defogger paint didnt stick to the chip as well as I had hoped. I may use spray varnish or something to seal it this time.
Ta
