- Nov 25, 2001
- Niagara Falls, Ontario, Canada
Hi guys,
I've been running prime95 torture test, and toast to test my overclock stability. Toast is crashing, at the same or lower temperature that it is running the Prime95 torture test at for hours. Toast seems to be running good at a stable temperature, I've sat and watched it for an hour, then gone away, and come back as often as possible, while it's still running the temp won't have budged, then I'll go back to it and find it has rebooted. Happens after about 3 hours. It will run the p95 test overnight, no problems though.
Have I got something to worry about or has Toast got issues?
I think Toast was crashing at lower speeds also. (been a while since I've been there
3Dmark can also loop for hours if I'm conservative with the GPU speed.
thanks,
Road Warrior
thanks,
Road Warrior
