Welcome to the forums!!
Next time try to post this in the AMD CPU's subsection. As you can see this section is for anything that is not entirely specific to AMD or Intel. This would be AMD specific. To you and all others out there, try to post in the right section.
Don’t worry its not a major mistake, we all do it every now and then, but it really gets annoying seeing about 20 threads every day that are just in this section but belong in AMD or Intel.
Anyways, if you can actually see the processor, you will be able to tell if it's a Palomino or a Tbred because of the core. If the core is square and has the numbers and letters imprinted right on it, it’s a Palomino. If it is rectangular and has the numbers and letters on a black sticker its a Tbred. Also the code should start off with something like AXDA1800 DUT3C afdhasdfhao8sdf0r630q2ytq43t JIUHB 0308 UPMW
That is just an example but if you see a "DA" after the "AX" than its a Tbred. If not it’s a Pally. If you see things like "AGOIA" or "AGOGA" instead of the JIUHB, it’s a Palomino. If it’s a tbred and ends in A it will be a Tbred A if it is a Tbred B it will end in B.
Also you can download wcpuid that should tell you. If it is model 6, it’s a Pally, model 8, a Tbred.
If it is a Palomino core, then it will be locked and you will have to join the L1 bridges. The Tbred's are unlocked though. Also we will have to know what core type and the code on the lable or core to know how well it overclocks. If you can tell us everything except the long part with all the numbers that dont make any sense that would be great so in the quote tags below, it would be great if you could give us everything EXCEPT the part in the red. It wouldnt hurt if you gave it to us anyways, just that most people cant tell that much from that part.
I hope that helps! Good luck.
-Amd0Cer
