- Jul 14, 2001
- Edmonton, Alberta
My friend just recieved his XP2100 processor today and its running 100% solid @ 1950MHz and the processor is locked with the 13X multiplier! All he did was raise the FSB to 150 (300MHz) and the voltage @ 1.85V.
So, his XP2100 is running rock solid at 1.95GHz, not bad!!
Remember, this is air cooled, his max temp using the Thermalright SK-6 is 49C at 1950MHz 1.85V.
EDIT: UPDATE!: We got a 152MHz (304MHz BUS) working which means the CPU is running at 1976MHz. Ok, the computer would run 99% fine but only now Prime95 Torture reports an error when we try to go past 1.95GHz. Unfortuneatly, he does not want to modify his motherboard to get a higher voltage than 1.85V so it looks like 1950MHz is the highest for his processor.
Man, I bet with 1.900V, he could hit 2GHz.
AXIA
AXIA
