XP2500-M or XP2600-M???
Demon Keeler
Sydney, OZ
hey guys! I've read a fair few ppl say that the 2500-M is a better o/cer than the 2600-M model! is this true and if so why as from the specs one would think thay'd be almost identical.
thanks! :beer:
DarkDraco
look at the thread where people posted their steppings and their OC on their mobiles. i personally got the 2500 cuz it seems to OC higher than the 2600
c627627
c(n*199780) Senior Member
Lottery.
Very early 2400+ mobile Bartons hit amazingly high overclocks.
Now any 2400+, even the 35 watters can hardly match average 2500+ mobile Barton overclocks.
Right now, I think as long as you don't go with 2400+, your chances are similar.
Knee-Dragger
Oregon
I can't say which is better, I for one always like More more more more. I'm addicted... to MORE!! So I got the 2600+. I'm glad I did too. I got it from NewEgg back in June.
ap673
Ya i'd say the xp2600, great overclocker, amazing temps. Just make sure you get the IQYHA MPMW stepping.
buddhafumes
Yea, my mobile 2400+ is awesome. But now I guess the 2500+ seems to be better than the 2600+. Not to mention its cheaper. So I guess you should go with the 2500+ if you want good price/performance.
blinky2183
... wtf, all the 3ghz+ OCs i have seen have been with 2600m's, and i havent seen any super high clocking 2500m's so why would u recommend 2500?
i dont get u people
ap673
Dude just go xp2600-m, im at 2.6ghz, 42c load with just air (slk-900A/TTSF2)
buddhafumes
Yeah there might be higher oc's with the 2600, but maybe less people get to that oc? I knew someone who's 2600 only got to 2.3, and thats the main reason I would recommend getting the 2500+. My cpu runs pretty hot, but thats because I've had AS3 (yes 3) on it for maybe half a year (I have a Tt silent boost). I guess its on the quality cpu you get.
Drec
its luck of the draw really, some 2500+s will beat 2600+'s and vise versa, id go with a 2600+ tho.
David
Forums Super Moderator
If it all comes down to luck, I would say look at the price difference. If there isn't much of a difference stick with the 2600, if there is a big jump get the 2500+.
ap673
Price is not an issue, its like 5-10 bucks. Usually people go with xp2600-m's cuz they have a higher chance of getting a good overclocking stepping.
avalanche83
Grand Rapids, MI.
There is alot of variables that goes into the specs. The three biggest that are that they both have the same FSB which is big now saying that the multipliers are locked on both, they have the same L2 cache, but the only difference in the two is that at stock the 2600 is 2.0GHz and the 2500 is 1.88GHz. So if the price is close I'd go with the 2600 easily.
jonspd
Super Speedy Senior
The Muilt's on the 2500 and 2600 mobile's are locked when did they do that AFAIK all mobile xp's are unlocked the desktop xp's however where locked some time back.
jonspd
Super Speedy Senior
NP @ all I guess you didn't see the little -m in the 2500 and 2600 in the title? hehe/
Drec
i'd be more worried about what mobo your getting then a 2500 or 2600.
