- Jul 9, 2002
- Sotira, Cyprus
Hi,
Today I am assisting a client recover his files that had been encrypted with a variant of the TeslaCrypt ransom virus.
Anyhow long story short I am using a tool called Yafu which you can find here
http://download.bleepingcomputer.com/td/yafu.zip
Basically, the last few days I have been priming my CPU at 5.0Ghz with 1.4975v with Small FFT for over 8 hours without any issues. Max temps was peaking at 60C. My watt meter was always around 420W - 450W
At this moment in time I am using the Yafu tool to discover the prime numbers that will be used to discover the private key....
The program is using 7 cores and watt usage is alternating between 360W - 390W but the temp spikage is heavy, peaking at 63C so far.
Ambient temps are 1C higher today.
So it looks like Yafu is pretty good at hammering a system!
Anyhow just wanted to put this out there.
For lolz, I did a search for 'Yafu vs Prime95' and look where it appeared
http://www.mersenneforum.org/showthread.php?p=424373#post424373
Brand new posts, so looks as if there are others who are doing comparisons.
