http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=16874886
Mobo: Gigabyte GA-P67A-UD7 ($330-350ish)(although I know its there are cheaper ones, I have read so many incredible reviews about it, I got stuck in my mind, this was THE ONE to get. If someone can point to another (better value, but still awesome mobo, let me know) (this will be to date, the most expensive mobo I'd ever have bought)
Vcard: EVGA GeForce GTX 570 (Fermi) ($350)
(was going to consider the evga 2win, but after further investigation, i think im going to pass, and the 590 will be too pricey)
CPU: Intel Core i7-2600 Sandy Bridge 3.4GHz (3.8GHz TB) LGA1155($300)
RAM: CORSAIR DOMINATOR 6GB (3 x 2GB) DDR3 1600 (12800) ($130)
RAM was only thing I just chose semi at random(based upon newegg reviews)
CPU cooling: Noctua NH-D14($90)
(was considering trying out watercooling but after researching, seems pointless on setup right now)
SSD: Intel X25-M SSDSA2MH120G2K5 2.5" 120GB SATA II MLC ($220
(I have over 2TB of regular standard 7200rpm (non performance HDDs)
(just wanted to try out OS and a few things and break into using some SSDs for first time)
$1400 ish total?
$1200(without new ssd)
If anyone could give any advice for better value/performance options. Let me know thanks!
(I might do a lil more price comparison shopping prior to purchase)(even though i love newegg)
Old system:
Abit IP35 Pro
intel quad 2.4ghz (Q6600)
Evga nvidia 8800GTX (I know its old!!) (pci express 1.0!)
some corsair or crucial 4gb (2x2gb) ddr2
Corsair 620HX 620W PSU (keeping for new computer)
Antec 900 case
a bunch of misc other stuff.
My only slight concern was possibly the PSU and better choice in ram/mobo
Corsair 620HX 620W is what I already have.
the 570GTX vcard says 550 minimum, and with a old q6600 using 10W more than new i7. I assume I will be okay.
Although minimal, I am planning on taking out HDDs that I currently have(from 5x 7200rpm to 3x 7200+1ssd)
$1400 ish total?
Old system:
Abit IP35 Pro
Antec 900 case
