- Jul 3, 2002
- Cairo, Egypt
Your Guide to a cool Processor without any ThermalX Stuff and only Generic Components
Hi,
I've written this guide to a lot of people who like me can't get all these fancy cooling components (AS3,Epoxy,Watercooling,Peltiers,ETC)
Using only Generic Fans and WITHOUT any Thermal Compounds I managed to lower my core Temp
from 63*C--->39*C on maximum LOad on an OC Celeron [email protected] @133 FSB @Default CoreVoltage
So let's begin:
First of all buy a good&cheap Heatsink from any shop,rip it from an old HSF,Take it from the retail HSF you bought the with the Cpu or even use your current one. Just get one...we need it(obviously
Clean it using Water,Soap,etc and make sure you dry it afterwards
Now you got the option of lapping it using some Glasspaper or leaving it as it is
I didn't lap mine but if you notice that the buttom of your heatsink is not plain then lap it
Now it is time to put it back in its place. IF u have thermal paste use it(very thinly) ,if u don't have Thermal Paste then don't worry -remember that i also didn't and if u have Arctic Silver you shouldn't be reading this =)
Mount it in back in its place (YES, Without the fan....YET) and make sure it fully touches the Cpu Core (IF u have ppga2(Tualtan,Northwood) DOn't worry about using some force to put it in its place but if u are using Amd or an Older intel Cpu (ppga) be careful not to crush the core(Especially AmdXP)
Now it is time to put the fans(YES, 2 Fans are recommended) i used 2 8Cm fans on the heatsink each one of them cooling a half of the heatsink(and one of them covering and cooling the ram)
I Really recommend going with 2 big Fans cause they theoretically cool a lot better than one good brandy fan because There are two motors each one of them spreading mucho of CFMs....
Go with at least 8Cm ones if u can manage to put in 2 12CM ones(quite Hard) then it will be much better
Just put them side by side not above eachother
screw the fans to the heatsink using the normal Screws that the Older fan was screwed by and the nconnect the cables of the fans
Here YOU GO
FINITO
Just as a notice if you like to keep your case Shut then you better buy another couple of Big Fans and put one in Front Down and the Other IN the Back UP just to get the hot air out and to make a good air circluation
PS:
Do it at your own Responsibility
I am not responsible for any damage
It worked Very great for me but might now work THAT great for you
My English is not that great(as i am still a high school student) but it is suffice for me to
write this article - If there are grammar,Content,Etc.. Mistakes i will be happy to receive them
at my Email [email protected]
Hi,
So let's begin:
Here YOU GO
FINITO
PS:
