Hi everyone. so, I was looking around for a stable overclock setup for my I5-2500k, arctic freezer 7 pro. Found one that seemed good from this site.
I plugged in the following settings into my system:
4.5 GHz.
"Vcore = NORMAL
DVID = +.050 (maybe +.060 max...but no more for 4.5GHz)(this setting becomes available when Vcore was set to NORMAL)
QPI/VTT = 1.150
PLL = 1.815
DRAM Voltage = MFG Spec (you may increase voltage just by a little from MFG spec)
Timing = MFG Rated Spec" (courtesy of SamSaveMax)
I am currently on the system, so I am not having any outstanding issues. No crashes, no BSOD or anything like that. However, I ran prime95 for 10-15 minutes before I HAD to stop the program.
The temperatures were reaching 90+ degrees C. From what I have read, 85 degrees C is good but no further.
Now here comes the question. I entertained the idea that since most of what I do is gaming, ArmA 3 etc. I figured I'd do a realistic test while actually playing a game. So I did, and reached temperatures of max 64 degrees.
I thought that was stable (for ArmA 3) since it is a CPU intensive game. Now, is it possible to stay at this overclocking configuration or should I 'dial-down' a bit? I figured Prime95 ran an unrealistic test of having your processor
at full-throttle all the time and therefore took the test with a grain of salt. I was looking into getting a new CPU cooler the Cooler master 212 evo which would probably solve the overheating issue.
Thanks in advance.
- H
4.5 GHz.
"Vcore = NORMAL
QPI/VTT = 1.150
PLL = 1.815
Thanks in advance.
- H
