- Sep 20, 2001
- Bakersfield, CA
How do you like it so far? I've always liked the Aorus Master features and aesthetics.
Some more tests and I found out that the mobo issue is related to a too thick backplate which is touching the PC case. There are many points where it can touch the case, I just have no idea where exactly. It's still weird that it started after 3h+ of tests and even after removing the mobo from the case it required clearing CMOS or reflashing. Everything was suggesting something else.
Another BIOS issue. When I save a profile then the mobo has problems booting at settings that were working without issues some minutes ago. What's more, when I load a profile with manual settings and then edit for example memory timings, save settings and restart ... then the mobo still uses timings from the profile, not these edited
Edit:
Every timing changes seem to work ... after turning off the PC, turning it on and when the mobo retrain memory ... and memory training takes ages ...
I really thought that retraining this way wasn't required for some years.
