Zalman Reserator XT $175 CAD - Worth it?
Aardvark Spleen
Victoria BC
There's a 2 year old Zalman Reserator XT for sale locally for $175 CAD. No water block. Wondering what your thoughts are. What should I offer the guy?
After 2 years of service you'd think the pump would be in need of replacing at some point soon... :shrug:
I'm kinda new to this stuff, you know.
Unit in question
I really dig external units, and I particularly like the basic concept of the Reserator XT, BUT I wouldn't buy one for one main reason.
Materials: Anodized Pure Aluminum This is a big one. If you're starting a water cooling setup from scratch, there's no reason for there to be aluminum anywhere in your rig. Zalman made a really bad choice when it chose materials for this unit.
It's a handsome unit, but they made some big mistakes in execution. I wouldn't buy one at any price. There are far better options these days.
^^^ Good call. The my existing gear is all copper. Didn't even think of the dissimilar metals thing. Thanks for helping me avoid a catastrophe.
The other thing is the reserator was designed as a passive cooler. All reviews I read back in the day regarding the original reserator said that unless the computer is in an airconditioned room or oyu have a floor fan blowing on it the thing doesn't work well, that kind of defeats the purpose of getting the kit.
Likewise, there was a knwn issue with all of the reserator units where the pumps would develop a rattle after a few months use which meant it wasn't silent anymore.
Regarding the reserator XT, well, a high end air cooler will outperform it. You'd be better off looking at a closed loop cooler like the H80 or H100, or even a high end air cooler. All of the early water kits were fairly rubbish from both Zalman and ThermalTake.
Frankly, I think it'd be a good cooler to avoid.
Lol, you're a rare breed then JeremyCt. Are you feeling like an endangered species? ;oP
Anyways, personally I lean towards the Corsair H80 and H100 closed loops or straight out air coolers. I find the H100 keeps my rig extremely cool. Heat isn't even the limiting factor in my overclock. Bigger fans lower temps a little more though to be honest, the stock fans were adequate anyway. I just wanted tougher/beefier fans.
