- Jul 30, 2014
Hi everyone,
Wanting abit of advice on how to finish off moving my old setup into my new Zalman Z3 Case. Everything is good to go only thing confusing me is the cables that come from the top of this case. I can only plug one of them to the power supply male molex into my PSU the other 2 3pins have no place to go. I also have a 3pin fan on rear of case that needs to be hooked up aswell.
All connections I query can be seen here http://extreme.pcgameshardware.de/attachments/745335d1402062309-zalman-z3-plus-luefterproblem-img_1574-1-.jpg
I take it the two with the black coord are the fans power which would be solved by the link provided below and the other two with red and black are the fan controllers? the biggest one I already have plugged in.
Would I be ok just getting this to plug into the 2 small ones with the black coord?
http://www.ebay.com/itm/Molex-4Pin-Male-Convert-to-4x-Male-3Pin-PC-Fan-Y-Splitter-Extension-Cable-Cable-/252361027047?hash=item3ac1e3ade7:g:UewAAOSw~oFXFjHB
I also have another 2 more plugs which will I think are for the fan controllers on the front of the box? (black and red coord) If so what connector do I need to get for these two ??
Regards,
Bandit.
Regards,
Bandit.
