I have AX6600 x2. One is connected to the cable modem in the living room acting of the network router. The other is in a front bedroom acting as a mesh node. The mesh node connects to a Trendnet 16 port unmanaged switch and then to the router. The mesh node connection has been inconsistent and now it just plain won't connect. When I connect to one of it regular ethernet ports it connects fine. When I connect to the WAN port for wired backhaul it won't even send the switch a signal. The cabling is fine. I use multiple Trendnet switches and they have always worked well.
Any suggested solutions? I could rewire the bedroom to the living room. There is a Cat5 cable in the wall from before we added on the home office and I wired the house with Cat6. I'd rather get the AXX6600 mesh node to work properly.
Thanks! Any help would be appreciated!
