FSP Hydro G Pro ATX 3.0 1000W Power Supply Overview
FSP Hydro G Pro 1000W
Today we look at the FSP Hydro G Pro ATX 3.0 1000-Watt power supply. The Hydro G Pro has been out for many years, but with Intel’s new ATX 3.0 standard FPS has decided to update one of its most popular products. Additionally, graphics cards have become increasingly demanding, drawing up to 200% of their rated thermal design power (TDP) for short bursts. To provide this extra power, a new 12+4 pin connector (12VHPWR) has been incorporated to ensure older, less capable power supplies aren’t used with the heavy draw GPUs. This overview will highlight everything about the updated Hydro G Pro ATX 3.0 features.
Specifications and Features
As we mentioned in the intro, the new Hydro G Pro 1000W follows Intel’s ATX 3.0 specifications and is PCIe 5.0 ready. As an 80+ Gold-rated PSU, it has an efficiency of 90% or better under typical loads. An ECO-mode switch at the back of the unit allows for semi-fanless operation for a quieter build. The 120 millimeter fan uses a fluid dynamic bearing (FDB) to increase longevity while producing less noise than standard ball bearing fans. The fully modular design and black ribbon cables help maintain a clean look. Japanese electrolytic capacitors are used for superior dependability.
Below is a list of the specifications.
FSP Hydro G Pro 1000W Specifications
ModelHG2-1000
Rated Output Power1000 Watts
Form FactorATX
80 PLUS CertificationGold
Input Voltage100-240Vac
Input Current16-6A
Input Frequency50-60Hz
PFCActive PFC
Efficiency90%
Fan TypeFDB Fan, 120mm
Dimensions(L x W x H)150 x 150 x 86mm
Operating Temperature0-50℃
ProtectionsOCP, OVP, OPP, SCP, OTP
Warranty10 Year
User Manual Download PageFSP Hydro G Pro User Manual.pdf
PricingAmazon: $209.99
Newegg: $336.99
We have also included a list of the major features found on the FSP website.
FSP Hydro G Pro 1000W Features
More Powerful with Compact Size
New HYDRO G Pro series upgrades from the original HYDRO G took the best features of HYDRO G series and made them even better. With smaller size, improves performance and more powerful output give you ultra-performance.
80 Plus® Gold Certification
HYDRO G Pro series is a power supply with 80 PLUS® Gold Certification that guarantees to operate at a minimum of 90% efficiency at 50% load of PSU rated power and as a result to reduce lots of electricity cost.
ECO Switch, Quieter and Longer Lasting Fan
When Eco Button is switched on, you can adjust the button to suit your needs, making it easier to run on lower consumption and whisper silent. The fan in the power supply will not operate when the power supply is under 30% loading for silent state.
Compatible with Latest PC-technology
Corresponds exactly to a variety of the latest CPU platform. Complies with Intel ATX12V V3.0 Power supply design guide and make sure the peak power in 12V supports for the latest Intel and AMD platform and delivers full power to your PC system.
Multiple-unit Connectors
The ATX 12V CPU power connector is able to support CPUs for enough watt. HYDRO G PRO series from 850W to 1000W packages 2 x 4+4 pins power connectors more than regular PSUs and provide the stable and peak output to your new config will require.
Off_Wet Technology
Hydro G Pro is covered with conformal coatings to guarantee reliable performance in a harsh environment. It can work perfectly with 95%RH while others cannot.
LLC Half Bridge Topology with DC-DC Module Design
New HYDRO G Pro series features extremely tight voltage regulation to make the output voltage regulation under +/- 1% at any load change and offer you supreme efficiency and voltage stability.
10-Year Warranty
FSP is committed to manufacturing high-quality and reliable power supplies. The Hydro G Pro series are backed by our 10-year warranty for both service and technically.
Packaging
The Hydro G Pro comes in a colorful flip-open box with a ton of information printed on it. There is also a paper sleeve with a couple of QR codes for product links and an online power supply calculator. The front of the packaging lists all the essentials like model number, maximum rated wattage, and efficiency rating. The back lists many features, specifications, and a high-resolution image of the internal components. At the top of the package is a diagram of the included cables, along with a table showing the quantity of each cable. The bottom displays three charts: The first is of the power specifications, the second is an acoustic noise chart, and the third is the efficiency chart. Inside we find the power supply sandwiched between two foam panels. The cables and accessories are located in a separate cardboard compartment.
Contents
Several accessories are included with the Hydro G Pro ATX 3.0 power supply. The fold up user’s manual and 12VHPWR connector pamphlet are multi-lingual and provide critical information for installation. There are four mounting screws, three reusable cable ties, two sets of stickers for changing the side panel colors, and a shorting plug for testing. A black microfiber bag keeps all the cables together and helps prevent losing them while in storage. The cables are bundled with two additional cable ties bringing the total number of straps to five. This is a fair amount of extras for a power supply, and it’s clear FSP is not skimping out on accessories.
Accessories
Accessories
Cables
Cables
The FSP Hydro G Pro ATX 3.0 Power Supply
Measuring 150 x 150 x 86 millimeters makes this a standard-sized ATX PSU, which is nice for such a powerful unit. Many 1000-Watt power supplies are considerably larger. The black finish has a mild texture giving it a matte appearance. It is fully modular and has five flat 5-pin peripherals, three 8-pin GPU, one 12+4-pin 12VHPWR, two 8-pin EPS, and a split motherboard connector. There is a large specifications sticker on the top displaying all the pertinent information and a serial number sticker. At the bottom is the 120-millimeter fan and a beautiful fan grill. At the center of the grill is the Hydro “H” logo machined into a metal disk, and the back of the casing is fully vented. In addition to the power input connector and on/off switch is an “ECO” switch. This toggles the fan to the semi-fanless mode. The fan will shut off when the power supply is under a load less than 30% of its maximum capacity. Located on either side are the standard stickers with white lettering and a light blue “G.” This is where the additional sticker can be used to change the color to either red or green.
Below we have included the power specs table.
FSP Hydro G Pro 1000W Power Specs (Rated at 50°C)
Rail+3.3V+5V+12V+5Vsb-12V
Max. Output20A20A83.33A2.5A0.3A
120W1000W12.5W3.6W
Total1000W
AC Input100-240 VAC~ 12-6A 50-60 Hz
Cables and Accessories
In total, 13 cables are provided. They are the black flat-type cables, except for the 12VHPWR cable, which has the wires harnessed in a plastic sheath. There is a motherboard cable and two EPS CPU 4+4 cables. They have included a single 12VHPWR 12+4-pin cable and three dual 6+2 GPU cables for VGA cables. Two peripheral cables are dedicated to SATA power with four connectors each. The other three cables offer a combination of SATA and Molex, with one offering a single FDD connector. Finally, the power input cable is heavily insulated and rated for 125 Volts and 13 Amps, or over 16oo Watts: More than enough.
Motherboard Cables
Motherboard Cables
VGA Cables
VGA Cables
Peripheral Cables
Peripheral Cables
Power Input Cable
Power Input Cable
Below we have added a table of the included cables with the total number of connectors for easy research.
FSP Hydro G Pro 1000W Included Cables
Cable TypeConnector# of CablesTotal # of Connectors
MotherboardATX 20+4 Pin11
CPUEPS 4+4 Pin22
VGAPCIe 5.0 12+4-Pin11
PCIe 6+2-Pin 36
PCIe 6-Pin00
SATA & PeripheralSATA 5-Pin514
Molex 4-Pin5
FDD 4-Pin1
Internal Components
Disclaimer: Do not open any power supply units without proper training. Failing to heed this warning can result in severe injury or death. We have opened this unit, so you won’t have to.
This is just an overview, so we will briefly highlight some main components. With the warranty properly voided, we get our first glimpse of the heart of the Hydro G Pro. FSP has chosen to solder on the input power connector, power switch, and ECO-mode switch. This is the preferred method as it is a more permanent connection than blade connectors. The soldering throughout the PSU looks good and gives us no reason for concern.
The primary capacitor is a Jamicon TK series rated for 450 Volts and 680 microfarads. The secondary capacitors appear to be Nippon KZE series and have a rating of 16 Volts and 2200 microfarad each. Jamicon is a Taiwanese-based company, while Nippon is headquartered in Japan. Finally, two bridge rectifiers are connected to small but adequate heatsinks and plenty of thermal paste. Plastic is used on the sides and under the main PCB to prevent possible mishaps, an industry standard. Everything here seems to be of good quality, with clean solder points.
Fan
The fan used to cool the Hydro G Pro is a Protechnic Electric 120-millimeter fluid bearing fan. With a maximum rated speed of 2700 RPM, it produces 96 CFM and reaches about 40 decibels. This is not the quietest fan on the market, so FSP was wise to include a built-in ECO-mode. Also, bonus points should be awarded for an excellent grill design. We don’t award points at OCF, so how about a crisp high-five instead?
Fan Rear
Fan Rear
Fan Front and Grill
Fan Front and Grill
Protechnic Electric 120 mm Fan Specifications
Model NumberMGA12012XF-025
Dimensions120 x 120 x 25 mm/ 4.7 x 4.7 x 1 inch
BearingFBR
Rated Voltage12 VDC
Rated Current.52 A
Power6.24 W
Speed2700 RPM
Air Flow96.2 CFM
Pressure0.217 in H2O
Noise Level40.3 dB(A)
Weight154 grams
Conclusion
FSP has been producing the Hydro series power supplies for many years, and we can see why it has been so successful. They offer a high build quality product at a reasonable price. FSP also happens to be one of the top providers of power supplies for many OEM companies. The Hydro G Pro in this review is the updated model built with today’s demanding PC components in mind. It features ATX 3.0 compliance, PCIe 5.0 connectivity, and all the aspects of the original Hydro G Pro. Two models are currently available at 850 Watts or 1000 Watts to fit your needs. It has an 80+ Gold rating, which is not much of a selling point nowadays. However, most users don’t need a platinum or higher-rated unit, and the higher cost is generally not worth it from a cost-savings perspective. Finally, FSP offers a generous 10-year warranty covering parts and labor making it one of the best available warranties.
We are pleased with the overall layout of the new Hydro G Pro ATX 3.0. It is in a compact chassis, provides plenty of power, and features everything a modern PC needs. With the 1000-Watt unit priced at just $209 on Amazon, we feel this is an excellent price and are confident in giving it our highest award.
Click here to learn what this means
Click here to learn what this means.
-John Nester (Blaylock)
Related Articles:
About John Nester 389 Articles
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Loading new replies...
W
Woomack
1
12,584 messages 1,354 likes
I like what FSP does in the latest PSU series. New PSUs look and work better than they used to.
I have the same PSU in tests right now, and it's quiet with Ryzen 7950X+RTX4080 under high load, and it doesn't require eco mode. I guess they just limited the fan's max speed as it spins slower than it's rated. I still use eco mode as it's not causing so much dust to gather inside the PSU.
Braided cables would be a perfect finish, at least for higher units. Painting is already better than in older series.
Reply 1 Like
