G.SKILL Announces ENKI Series AIO CPU Coolers
G.Skill enters the CPU AIO cooler market with its announcement of the new ENKI series liquid coolers. Custom designed with a convex copper cold plate and high-density radiator, the ENKI coolers are engineered for extreme performance. The new ENKI will be available in 240 mm, 280 mm, and 360 mm sizes. Pricing has not been announced yet so be sure to watch for future articles about this development. Continue reading for G.Skill’s press release.
G.SKILL Announces High-Performance ENKI Series AIO Liquid Coolers
(17 December 2020) – G.SKILL International Enterprise Co., Ltd., the world’s leading manufacturer of extreme performance memory and gaming peripherals, is excited to introduce a new product line of all-in-one CPU liquid coolers, the ENKI series AIO. Named after the ancient Sumerian god of water, the ENKI series AIO is a custom-designed AIO CPU cooler that focuses on high cooling performance by eliminating heat-transfer bottlenecks and engineered to efficiently extract heat from the CPU, through specially-selected low thermal resistance thermal paste, across the custom-tuned convex copper cold plate, and into the high-density radiator via widened, low-evaporation coolant tubing. Available in 360mm, 280mm, and 240mm radiator sizes, each ENKI series AIO includes 9-blade hydro-bearing cooling fans, ARGB lighting, and easy-to-install mounting bracket kits. Click the following link for the product video: https://youtu.be/XUdce1PLyH4
Custom-Tuned Convex Cold Plate & Stair-Shaped High-Density Micro-Fin Design
To achieve high-performance cooling and maximum contact with the CPU, the ENKI series AIO liquid cooler utilizes a custom-tuned convex cold plate design to minimize the travel distance of heat from the CPU through the thermal paste and into the solid copper cold plate. On the other side of the cold plate, stair-shaped high-density micro-fins are used to optimally guide the coolant intake-outtake flow for efficient heat transfer from the cold plate and into the coolant.
High Flow-Rate Coolant Tubing & High Density Radiator Piping
In order to quickly deliver coolant between the cooler head and the radiator, high flow-rate coolant tubes with 8mm inner diameter are chosen for the task. Each coolant tube is also constructed with thicker rubber walls for low coolant evaporation and are enclosed in nylon-braided sleeves for durability. The radiator is designed with high-density piping, which increases the surface area to facilitate efficient heat dissipation from the coolant and into the fins for effective cooling. Specifically, the 360mm and 240mm variant is designed with 3~4 more radiator pipes than typical radiators, while the 280mm variant has 6 more radiator pipes.
High Static Pressure 9-Blade Fan & Low Thermal Resistance Thermal Paste
The ENKI series AIO liquid cooler is equipped with high performance 9-blade hydro-bearing PWM cooling fans, selected for its high static pressure to maintain constant air flow. Included within the accessory pack, is a tube of server-grade thermal paste that features ultra-low thermal resistance, which enables quick heat transfer from the CPU to the copper cold plate.
Customizable ARGB & Product Availability
Each ENKI series AIO liquid cooler is equipped with 3-pin ARGB motherboard connectors, allowing customizable RGB lighting via motherboard lighting control software. Available in 360mm, 280mm, and 240mm, the ENKI series AIO also comes with a 5-year limited warranty. This product line of AIO liquid coolers will be available via G.SKILL distribution partners in 2021.
About G.SKILL
Established in 1989 by PC hardware enthusiasts, G.SKILL specializes in high performance memory, SSD products, and gaming peripherals designed for PC gamers and enthusiasts around the world. Combining technical innovation and rock solid quality through our in-house testing lab and talented R&D team, G.SKILL continues to create record-breaking memory for each generation of hardware and hold the no. 1 brand title in overclocking memory.
-John Nester (Blaylock)
About John Nester 399 Articles
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Loading new replies...
Avatar of Overclockers.com
3,199 messages 181 likes
G.Skill enters the CPU AIO cooler market with its announcement of the new ENKI series liquid coolers. Custom designed with a convex copper cold plate and high-density radiator, the ENKI coolers are engineered for extreme performance. The new ENKI will be available in 240 mm, 280 mm, and 360 mm sizes. Pricing has not been announced yet so be sure to watch for future articles about this development. Continue reading for G.Skill's press release.
Click here to view the article.
Reply Like
