GSkill has released new high-speed memory kits touting low latency with their new DDR4-4000 CL16 32GB (16GBx2) and DDR4-4400 CL16 16GB (8GBx2) SKUs. The new Trident Z Royal kits forgo the higher timings we are used to (CL19+) with much lower CAS latency timings for improved performance. Pricing wasn’t listed for the kits, but we expect these to fetch a premium over the existing modules with slower timings. These are said to be available now. The full press release is found below.
(25 September 2020) – G.SKILL International Enterprise Co., Ltd., the world’s leading manufacturer of extreme performance memory and gaming peripherals, is releasing new high-performance, low-latency memory kits at DDR4-4000 CL16 32GB (16GBx2) and DDR4-4400 CL16 16GB (8GBx2), and available across the Trident Z Royal, Trident Z RGB, and Ripjaws V series. Engineered with high quality hand-screened Samsung B-die components, these new memory specifications provide more efficient latency options at extreme frequency speeds.
High-Capacity 16GBx2 Upgrade for DDR4-4000 CL16
Now available with a larger kit capacity of 32GB (16GBx2), the highly optimized DDR4-4000 CL16-19-19-39 memory specification is an ideal performance upgrade for PC builds intended for gaming and content creation. Optimized with the latest 10th Generation Intel® Core™ processors and Intel Z490 chipset platform, this new memory kit can be seen validated on the ASUS ROG MAXIMUS XII EXTREME, MSI MPG Z490 GAMING PLUS, and ASRock Z490 AQUA motherboards with the Intel® Core™ i9-10900K, i7-10700K, and i5-10600K processors, respectively, in the screenshots below.
Extreme Low Latency DDR4-4400 CL16
Along with this wave of memory specification updates, is the DDR4-4400 CL16-19-19-39 16GB (8GBx2) memory kit. This new low-latency CL16 option is an ideal choice for overclockers and enthusiasts who are aiming for a higher benchmark score or a more efficient memory kit.
Availability
These high-capacity and low-latency memory specifications are available via G.SKILL worldwide distribution partners now.
Joe Shields (Earthdog)
Discussion
