Today, ID Cooling announced its latest CPU air cooler, the SE-226-XT. The new cooler has two SKUs available. One for ARGB lovers and an all-black version for those anti-RGB consumers. ID Cooling claims up to 250 TDP cooling capabilities and includes mounting hardware for all modern mainstream platforms. Pricing is set at a very reasonable $39.99 for the black model and $44.99 for the ARGB version though availability will be dependant on your region. Here is ID Cooling’s press release.
ID COOLING SE-226-XT ARGB and SE-226-XT BLACK
ID-COOLING today announced SE-226-XT ARGB and SE-226-XT BLACK CPU air coolers. Both coolers include the same black heatsink with 6 heatpipes and copper base. 120 mm ARGB fan and Black fan are used on ARGB / BLACK version respectively. SE-226-XT Series is designed to cool those processors with a TDP up to 250 W. Both models are built with a solid heatsink which is specially design with 100% RAM compatibility. Black coating is applied for a stealthy looking.
For SE-226-XT ARGB, the included 120x120x25mm fan is built with 2Ball bearing and has 8pcs rubber dampeners on all corners of both sides, running at 800 to 2000rpm with PWM support while pushing 56.6CFM air at maximum speed, noise level measured 16.2 to 31.5dB (A). For SE-226-XT BLACK, the included standard 120x120x25mm fan has 8pcs rubber dampeners on all corners of both sides, running at 700 to 1800rpm with PWM support while pushing 76.16CFM air at maximum speed, noise level measured 15.2 to 35.2dB (A).
ID Cooling SE-226-XT BLACK
ID Cooling SE-226-XT ARGB
An extra fan clip set is included for a push-pull configuration. ARGB 1-4 splitter cable and a cable controller are included in the ARGB edition.
The bundled thermal grease is named ID-TG25, which has a thermal conductivity of 10.5 W/m-K.
With a set of metal mounting brackets, SE-226-XT is compatible with all mainstream CPU sockets, including Intel LGA2066/2011/1700/1200/115X and AMD AM4.
MSRP for SE-226-XT ARGB: 44.99USD.
MSRP for SE-226-XT BLACK: 39.99USD.
Available date: Depends on region.
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Thermalright is a name that has been synonymous with enthusiast-level air cooling for quite a while now. Their venerable Ultra 120 Extreme (aka the TRUE) has won accolades and was once the favorite high end air cooler among overclockers worldwide. In recent times, the TRUE has fallen behind a little bit. While still one of the top air coolers, it’s not quite standing alone on the podium as it once was.
Thermalright aims to up their game with the recently released Venomous X, which we’re going to have a look at today.
Today, Alphacool announced the Eisbaer Pro Aurora series All-In-One CPU cooler line-up. The Eisbaer Pro Aurora features a larger cooling plate and mounting system for compatibility with some of the largest CPUs on the market including AMD’s Threadripper, Intel’s LGA3647, LGA4189, as well as fitting the new LGA1700-based systems. Full copper NexXxoS ST30 radiators in 280 mm and 420 mm are available and feature quick-release couplings for expandability. For complete details, continue reading Alphacool’s press release.
Today, ID Cooling announced its latest CPU air cooler, the SE-226-XT. The new cooler has two SKUs available. One for ARGB lovers and an all-black version for those anti-RGB consumers. ID Cooling claims up to 250 TDP cooling capabilities and includes mounting hardware for all modern mainstream platforms. Pricing is set at a very reasonable $39.99 for the black model and $44.99 for the ARGB version though availability will be dependant on your region. Here is ID Cooling's press release.
We use cookies to ensure that we give you the best experience on our website. If you continue to use this site we will assume that you are happy with it.OkPrivacy policy
No replies yet
Loading new replies...
