Kingston HyperX Genesis 4×4 GB DDR3-2133 RAM Review
Kingston is a well known company for their multitude of storage solutions, consisting of RAM, USB Drives, Solid State Drives, and Flash cards. Entering the market in 1987 with a surface mount memory chip, Kingston is a veteran when it comes to the storage market. Today, we have a quad channel kit of their HyperX Genesis desktop RAM line up ready for a thorough testing.
Specifications
Here’s a picture of the label with the part number information, and here’s the Kingston HyperX Genesis page.
Label
Label
Looking at the SPD tab in CPUz we can see the rated timings and voltages of this kit and how I manually set the timings; 1067 MHz (2134 MHz DDR) clock speed,  11-12-11-30 timings, and 1.65 V vDIMM. The timings on this kit seems high compared to the typical 9-11-10-28 timings of 2133 MHz 4 GB 1.65 V sticks from other manufacturers. The combination of high voltage and high timings makes me wonder how this kit will do with overclocking, tightening timings, and/or reducing voltage.
Memory and SPD Tabs
Memory and SPD Tabs
However, if I use the XMP profiles to set the speed, timings, and voltage for me, I get the following results. Neither of the XMP profiles match the SPD. I was also told by Kingston that this set was rated at 11-12-11-30, so with all the conflicting info, I don’t know what to trust. However, for this review, I’ll be using the specs in the SPD and that Kingston told me, 2133 MHz 11-12-11-30 1.65 V.
XMP Profile 1
XMP Profile 1
XMP Profile 2
XMP Profile 2
HyperX Genesis Photo Op
I love the packaging that Kingston used with this set of RAM. The sticks just fit into slots in the box and stand up. There are ~10 slots for holding RAM, so this box is definitely a keeper for all the extra RAM I have laying around.
Packaging
Packaging
Box Opened
Box Opened
The Genesis HyperX sticks have low-profile heatspreaders that shouldn’t interfere with any heatsink installation. The heatspreaders on this particular set are bright blue with 12 pairs of holes on both sides. Kingston’s HyperX logo is on both sides as well, with one side denoting DDR3 and the other displaying Genesis. Some people gripe about green PCBs used with components, but they will be barely noticeable once installed.
The HyperX RAM
The HyperX RAM
Both Sides
Both Sides
Extreme Angle
Extreme Angle
Extreme Angle
Extreme Angle
Test Setup & Methodology
Test Setup
CPUIntel i7 3930K
MotherboardGigabyte GA-X79-UD3
RAM Kit 1
4×4 GB Kingston HyperX DDR3-2133 11-12-11-30 1.65v
RAM Kit 2
4×2 GB G.Skill Eco DDR3-1600 7-8-7-24 1.35v
Graphics CardEVGA GTX 580 Classified 3 GB
Solid State Drive40 GB Corsair Force
Power SupplySeaSonic SS-1000XP
Operating SystemWindows 7 x64 SP1
The benchmarks used are as follows and they were run using their default settings.
  • MemTest86+ – DOS-based RAM testing software
  • LinX – CPU stressing program and the amount of RAM used can be specified
  • SuperPi 1M – Single-threaded pi calculation to 1 million digits
  • SuperPi 32M – Single-threaded pi calculation to 32 million digits
  • wPrime 32M – Multi-threaded square root calculation of 32 million numbers
  • wPrime 1024M – Multi-threaded square root calculation of ~ 1 billion numbers
  • x264 – Video encoding at 480p
  • x264 HD – Video encoding at 720p
  • Cinebench R10 – Rendering test
  • Cinebench R11.5 – Rendering test
  • SisSoft Sandra – Memory bandwidth and latency test
  • AIDA64 – Memory bandwidth and latency test
  • 7zip – Compression test
  • POV Ray – Rendering test
RAM Installed
RAM Installed
Results
The results of benchmarks between RAM kits are usually very close without one kit running away with tests when everything else is constant. So, the following results are basically the differences between RAM speed and timings when running in quad channel mode on LGA2011.
MemTest86+ & LinX
I used MemTest86+ v4.20 to test the RAM at its rated specifications for over two hours without any errors. That seems to show that maybe the SPD and Kingston’s word was correct and the XMP profiles are just messed up.
However, LinX is a different story. I cannot make a single pass of LinX with the RAM at its rated specs of 2133 MHz 11-12-11-30 1.65 V. When the RAM is set to its rated specs, LinX fails at the exact same time of 23 seconds every time I try running the program at its default settings. At first, I thought it had to be the CPU somehow, so I tried locking the CPU to clocks well below the rated 3.2 GHz and running LinX. The results didn’t change, I would still fail to make a single pass and it would freeze at a certain time (depended on CPU clocks) every time I would run the stress test. Then I tried underclocking both the CPU and RAM by setting the CPU to 1.6 GHz and the RAM to 1333 MHz 9-9-9-24 1.5 V. Then, I actually passed all five runs of LinX with the only thing being changed was the RAM settings. So, I increased the CPU clocks to stock and even up to 4 GHz while keeping the RAM at 1333 MHz 9-9-9-24 and LinX would make it through all 5 passes every time. However, once I increased the RAM to its rated specs, LinX would start failing again.
LinX Failing at stock
So, even after these stability tests at stock settings, I’m still unsure if the RAM should actually run at 2133 MHz 11-12-11-30. I didn’t have the best feeling about the RAM after these results, and I thought I would probably see some instability during the other benchmarks as well. However, I stuck with the rated speed and timings according to the SPD and continued testing.
SuperPi 1M/32M & wPrime 32M/1024M
Both SuperPi and wPrime like the additional MHz the Kingston kit has over the G.Skill kit. Although, the difference was only 0.04-1.74%. These number crunching benchmarks show that there’s not a lot of difference between sets for this application, but speedy RAM is a little better for the math. No sign of instability in the HyperX in these tests, so that’s a good sign.
SuperPi & wPrime
SuperPi & wPrime
x264 & x264 HD
Interestingly, there seems to be a split decision as far as x264 encoding is concerned. The G.Skill kit beat the Kingston kit in Pass 1 during both the 480p and 720p encoding benchmarks, but Kingston won out on the Pass 2 of both benchmarks. The difference between Pass 1 and Pass 2 is that the first pass is just a scanning pass so that the encoding pass doesn’t have to guess what will be in the next frame based on the current frame. So, the actual encoding pass is a very, very small amount faster with the HyperX kit. Again, no HyperX instability when encoding either.
x264 & x264 HD
x264 & x264 HD
Cinebench R10 & R11.5
We’re on to rendering with Cinebench, and it looks like this benchmark may prefer the tighter timings of the G.Skill kit over the higher clock speed of the Kingston HyperX. G.Skill won on both counts in the Cinebench rendering tests, albeit not by much. The rendering tests were also free of troubles for the HyperX, it’s starting to look like there’s no issues with the RAM.
SiSoft Sandra & AIDA64
Finally, we see a significant difference between the two RAM kits. Bandwidth is significantly higher with the HyperX RAM, especially in the Memory Bandwidth test. The latencies are very close between the two, and who would can notice 0.2 ns anyways? The HyperX wins out in Sandra for sure!
SiSoft Sandra
SiSoft Sandra
As you can see, in AID64, the HyperX kit beats the G.Skill by more than a percentage point in all the tests except the writing test. The G.Skill RAM wins only by a hair in the write test, coming out in front by 0.34%. This test goes to the HyperX as well!
AIDA64
AIDA64
These tests were where I thought the HyperX would be most likely to show instability if there was any. The kit made it through these tests multiple times without a hiccup!
7zip & POV Ray 3.7 RC3
Now for a compression test and another rendering tests, and the last chance for the HyperX to to show instability at 2133 MHz 11-12-11-30. In the 7zip compression test, it looks like clock speed has the advantage over timings. For POV Ray, just as with the Cinebench results, the G.Skill comes out ahead; it’s just something about the rendering tests that the G.Skill really likes. Any instability with the HyperX? Nope, both test ran fine.
 7zip & POV Ray
7zip & POV Ray
Overclocking
On the LGA2011 platform, overclocking RAM is a tough task because the RAM multipliers and gear ratios are incremented in rather large jumps. This makes RAM overclocking almost solely dependent on how much the bclk can be fine tuned outside the gear ratio. Just check the table below, and you’ll see what I mean…
100 MHz1.001.251.662.50
8.00800 MHz1000 MHz1328 MHz2000 MHz
10.661067 MHz1333 MHz1771 MHz2667 MHz
13.331333 MHz1667 MHz2213 MHz3333 MHz
16.001600 MHz2000 MHz2656 MHz4000 MHz
18.661867 MHz2333 MHz3099 MHz4667 MHz
21.332133 MHz2667 MHz3541 MHz5333 MHz
24.002400 MHz3000 MHz3984 MHz6000 MHz
26.662667 MHz3333 MHz4427 MHz6667 MHz
29.332933 MHz3667 MHz4869 MHz7333 MHz
32.003200 MHz4000 MHz5312 MHz8000 MHz
As far as increasing the clock speed, it turns out my board/CPU can do 102 MHz bclk, and with the RAM multiplier of 21.33, it turns out to be a 42.66 MHz overclock for a total of 2176 MHz.
I tried tightening the timings down at 2133 MHz and 1.65 V, but didn’t get very far before getting multiple BSODs. I started getting crashes at 10-12-10-29, and anything tighter than this caused a reboot loop after saving and exiting the BIOS. Next, I reduced the speed to 1600 MHz and 1866 MHz then tried tightening down timings at those speeds. The following two pictures show the lowest timings I could get while being able to load Windows and pass MaxxMEM. At 1600 MHz, I was able to tighten down to 7-9-8-24, which isn’t bad at all, but doesn’t quite match the G.Skill Eco at 1600 MHz 7-8-7-24. At 1866 MHz, the timing gladly went to 9-11-10-26, but no further.
HyperX @ 1600 MHz 7-9-8-24
HyperX @ 1866 MHz 9-11-10-26
Conclusion
The Kingston HyperX Genesis kit has some odd discrepancies between the what the sticks are claimed to be rated for and what the XMP profiles set the RAM at when used. Even the SPD table and XMP profiles do not match. There is also an odd issue with LinX and this kit of RAM when set to its rated specs of 2133 MHz 11-12-11-30. However, after the completion of these benchmarks, it seems to me that the HyperX runs fine at 2133 MHz 11-12-11-30 and LinX may be just an outlier.
The results of the benchmarks have the HyperX coming out ahead in four out of the five types of tests, as follows:
Kingston HyperX Genesis DDR3-2133 11-12-11-30
  • Math Computation
  • Bandwidth and Latency
  • Compression
  • Encoding
  • Rendering
As far as overclocking, it’s hard to come to a concrete conclusion because of the limitation of the platform, but from what I was able to test, I wasn’t impressed with the clock speed overclockability, but tightening the timings down wasn’t bad when lowering the clock speed. However, these are running at 2133 MHz already, which is darn fast itself, but the timings can’t be tightened much at 2133 MHz either. I was hoping to get to the 9-11-9-28 range like some other 2133 MHz kits on the market. However, lowering the speed of the RAM allowed the timings to be tightened quite a bit more. As always, overclocking is just a bonus and never a guarantee, so limited overclocking doesn’t go against the kit.
Overall, the Kingston HyperX Genesis kit did well throughout my 24/7 use and testing. The kit just needs a few kinks worked out with the XMP profiles and then there wouldn’t be anything wrong with this kit. I expect the MSRP on this kit to be around $140 since comparable 4×4 GB 2133 MHz 11-11-11-30 kits are around that price point at Newegg. With the only con of this kit being incorrect XMP profiles, which can be easily set manually in the BIOS/UEFI, the kit is still worthy of an approved stamp.
One last thing… Thanks goes out to Kingston for sending Overclockers.com a sample and making this review possible!
– Matt T. Green (MattNo5ss)
Loading new replies...
Avatar of kskwerl
kskwerl
535 messages 0 likes
nice review Matt, my moms got some HyperX in her comp (my old comp) and I've never had any complaints about Kingston or their HyperX memory.
Reply Like
Avatar of hokiealumnus
hokiealumnus
Water Cooled Moderator
16,561 messages 26 likes
Great review Matt!
I also want to feature this photo here because it's brilliant. Great job on that one. :thup:
(Even if you forgot to watermark it. ;) )
Reply Like
Avatar of MattNo5ss
MattNo5ss
5up3r m0d3r4t0r
8,808 messages 0 likes
These are actually some good sticks despite having the highest timings I've seen.
EarthDog mentioned he has had trouble with a XMP 1.3 quad channel kit from another manufacturer and a X79 board reading the XMP profiles. I'm not sure if this kit is XMP 1.3, but if it is, then my XMP reading issue may be a motherboard issue.
@hokie
Thanks! That picture is actually a hand painting by Bob Ross using watercolors and a spork... :rolleyes:
Reply Like
Avatar of deseroner
deseroner
27 messages 0 likes
i set this memory to 2400 on my z68 mivz 3770k , man this new ivy likes it high on the memory.
Reply Like
