Table of Contents
31 July 2020 – Today, Lian Li launched its first closed-loop All-in-One Liquid Coolers, the GALAHAD 240 and GALAHAD 360. The pair of coolers are available in black or white with 400mm long color-matched and braided tubing. A unique triple chamber pump works in conjunction with the high-density aluminum radiator to keep your CPU temps in check and the addressable RGB lighting keeps your PC looking cool. Here is the official press release from Lian Li along with the components specifications.
LIAN LI Launches AIO Water Cooling Products with GALAHAD 240 and 360
July 31st, 2020, Taipei, Taiwan – LIAN LI Industrial Co. Ltd., a leading manufacturer of aluminum chassis and PC accessories, is proud to announce its first closed-loop All-in-One Liquid Coolers, the GALAHAD 240 and GALAHAD 360. Available in black or white, the new GALAHAD series features a unique triple chamber pump design and PWM high static pressure fans to ensure optimal thermal and noise management. Keeping ease of installation, flexibility, and style in mind, the GALAHAD is compatible with the latest Intel and AMD sockets and is equipped with 400mm braided tubing. Fans and CPU block feature addressable RGB which can be synchronized with your motherboard software for unified lighting effects.
Focused on performance
The GALAHAD 240 and 360 deliver on performance by combining a unique triple chamber pump design with low-noise fans engineered to deliver an optimal airflow over the high-density aluminum radiator. The CPU block of the GALAHAD consists of a cold plate chamber, a connecting chamber and a pump chamber. The special design eliminates water flow dead zones while providing a direct path and maximum pressure over the fins of the cold plate which results in fast heat dissipation. With all compatibility accessories for both AMD and Intel sockets included, the GALAHAD is easy to install.
With a pump operating at less than 20 dBA at full speed and PWM fans that can operate between 800 and 1900 RPM, the GALAHAD will not affect your gaming experience with disturbing background noise. Capable of offering a maximum airflow of 69.17 CFM and air pressure of 2.6 mmH20, the included high static pressure fans of the GALAHAD are quiet yet powerful, thanks to their industrial-grade motor, fluid dynamic bearing and extra magnetic support which all work together to eliminate friction and vibrations.
Premium quality
While the GALAHAD performance is outstanding, it also features premium quality and design. The aluminum housing of the radiator and CPU block gives the GALAHAD a classic and robust look. Paired with 400mm high-end braided tubing, the GALAHAD is a perfect fit for midi tower and full tower chassis.
The fans and CPU block are equipped with addressable RGB LEDs that can be synchronized with the motherboard lighting software. Capable of supporting a wide array of lighting effects, a total of 17 modes including 7 solid colors are available. The included RGB controller makes switching between effects a breeze. In addition, the CPU block can be rotated to ensure a properly aligned logo no matter what the orientation of the block is. It also features a magnetic aluminum cap which can be removed and reveal the LIAN LI logo and a brighter lighting effect.
Backed by a 5-year warranty, the GALAHAD AIO is available for pre-order starting July 31st, 2020, at MSRP $119.99 USD for the 240, and $149.99 USD for the 360. For more information visit the official product page: https://www.lian-li.com/galahad-240-360/
LIAN LI GALAHAD 240/360 Specifications Radiator Materials Aluminum and plastic Radiator Dimensions (L) 397.5mm x (W) 123.5mm (H) 27mm /
(L) 273mm x (W) 123.5mm (H) 27mmFan Dimensions (L) 120mm x (W) 120mm x (H) 26mm Fan Speed 800 – 1900 RPM (PWM) Fan Airflow 69.17 CFM Fan Air Pressure 2.6 mm H2O Fan MTTF 40,000 Hours Fan Power Connector 4-Pin Fan Rated Voltage 12V DC Pump Dimensions (L) 87.1mm x (W) 74mm x (H) 62mm Pump MTTF 70,000 Hours Pump Noise Level < 20 dBA Pump Power Connector 2510-3-Pin Pump Rated Voltage 12V DC Compatible CPU sockets Intel: LGA 115X, LGA 1366, LGA 775, LGA 1200, LGA 2011, LGA 2066
AMD: AM4Warranty 5 years (Fans limited to 2 years)
The new LIAN LI GALAHAD AIO is now available at NEWEGG:
240 White: https://www.newegg.com/p/2YM-002Y-00004?Item=9SIAFSTBGD1647
240 Black: https://www.newegg.com/p/2YM-002Y-00005?Item=9SIAFSTBGD1707
360 White: https://www.newegg.com/p/2YM-002Y-00002?Item=9SIAFSTBGD1431
360 Black: https://www.newegg.com/p/2YM-002Y-00003?Item=9SIAFSTBGD1569
About LIAN LI
LIAN LI Industrial Co. Ltd is one of the world’s leading consumer brands for PC chassis. With over 20 years of experience in designing and manufacturing PC chassis under its own name and community projects, the company has produced some of the most iconic designs to date. LIAN LI’s award-winning products are sold worldwide to PC enthusiasts, builders, and gamers. To learn more about LIAN LI, please visit http://www.lian-li.com/. You can also visit LIAN LI on Facebook, Instagram, and YouTube.
Loading new replies...
1
1
1
1
1
