Lian Li
Table of Contents
Lian Li launched its first performance-based P28 120 mm PWM UNI FAN. With a thickness of 28 mm, the new P28 can move more air compared to standard 25 mm fans. At the heart of the new UNI FANS are Fluid Dynamic Bearings (FDB) for an outstanding balance of longevity and noise reduction. Additionally, a magnetically mounted 3-speed fan controller allows the user to fine-tune the balance between performance and silence. Available in black or white, each fan costs about $25 and can be purchased individually or in a 3-pack. Lian Li’s press release below provides purchase links and complete specs.
LIAN LI Launches First Performance-Focused UNI FAN with the P28
Lian Li P28 UNI FAN
May 12th, 2023, Taipei, Taiwan – LIAN LI Industrial Co. Ltd., a leading manufacturer of chassis and PC accessories, announces its first performance-focused UNI FAN with the P28, a 120mm PWM fan available in black, and in white. With a 28mm thick frame, Liquid Crystal Polymer blades, Fluid Dynamic Bearing, and 3-speed modes: quiet operation, balanced noise/performance, and maximum performance, the P28 is geared towards performance. As with all UNI FANs, the P28 can be interconnected to create clusters of fans capable of being powered via a single cable, and up to 2 clusters can be bridged with an extension cable. For users wanting added flare without sacrificing performance, an optional Side RGB Strip accessory is added to the side of the fan.
The P28 features a 9-blade design made of liquid crystal polymer (LCP), a stronger material capable of supporting higher speeds without deformation for tighter tolerances with the fan frame (0.6mm). Combined with an overall frame thickness of 28mm, the increase in the surface area of the blades results in added performance. In addition, the P28 is equipped with Fluid Dynamic bearings (FDB) for the fan motor to operate quieter and smoother. The use of a thicker fan frame, sturdy LCP blade material, and the FDB result in great performances, and quieter operation.
The P28 comes with a controller which can be magnetically mounted anywhere in the case and offer 3-speed profiles. Users have the option to opt for quieter operation in L mode, a perfect balance of noise and performance in M mode, or maximum performance in H mode.
UNI FAN P28 Performance
Mode
Airflow
Static Pressure
Noise
Speed
L
44.94 CFM
1.3 mmH2O
20.4 dB(A)
200 – 1300 RPM
M
77.76 CFM
3.62 mmH20
28.1 dB(A)
200 – 2200 RPM
H
92 CFM
4.79 mmH20
32.1 dB(A)
200 – 2600 RPM
The P28 can be interlocked and daisy-chained together to create clusters of fans that only require a single cable to be powered on. The innovative approach introduced with the original UNI FAN SL120 greatly reduces the number of cables required to power a large number of fans, making cable management a breeze. In addition, the P28 has removable interlocking keys to improve compatibility with radiator fittings, and support for an extension cable to bridge two clusters of fans (up to 6 fans max) to a single controller, further reducing cable clutter.
Lian Li P28 UNI FAN
Optional Side RGB Kit​
While the P28 is focused on performance, users also have the option to replace the side aluminum strip with a Side ARGB Strip accessory. The strip can be added to a single side of the fan, or both, and is powered via a standard 5V ARGB cable and can be daisy-chained seamlessly like the fans. By adding the side ARGB strips to the P28, available in black and white, users can achieve the same sophisticated RGB look as the UNI FAN SLV2, without sacrificing performance.
Lian Li P28 UNI FAN
The UNI FAN P28 is available for pre-order starting May 12th, 2023.
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
The Megahalems comes with no fans of its own. You can choose your own fans, but what fans do you get? How well do they cool your system? How loud are they? When I decided I wanted to cool a 4GHz Core i7 860 with a Megahalems, I figured I would test a few fans and see how well they did. Needless to say, I sort of got carried away. I tested 65 fans in many configurations. Read all about it.
When computer enthusiasts think about high-end, ultra quality cases, what’s the first name that comes to mind? Yes, that’s rhetorical; we all know it’s Lian Li.
Today we’ll look at a Lian Li case, the PC-V1020. It’s not a water-cooling oriented case as the PCX-900 was, but will it do well for air-cooled machines?
Lian Li launched its first performance-based P28 120 mm PWM UNI FAN. With a thickness of 28 mm, the new P28 can move more air compared to standard 25 mm fans. At the heart of the new UNI FANS are Fluid Dynamic Bearings (FDB) for an outstanding balance of longevity and noise reduction. Additionally, a magnetically mounted 3-speed fan controller allows the user to fine-tune the balance between performance and silence. Available in black or white, each fan costs about $25 and can be purchased individually or in a 3-pack. Lian Li's press release below provides purchase links and complete specs.
Loading new replies...
