Lian Li
Table of Contents
Recently, Lian Li reveals multiple prototype components at the Digital Expo 2.0. Several new cases were featured along with a new All-In-One CPU liquid cooler and new and improved fans. The press release below highlights these new future products but we would encourage everyone interested to also check out the Digital Expo for themselves on YouTube linked here. Here at Overclockers, we are especially excited about these new prototypes as we were allowed an insider’s look several months ago and were given the opportunity to offer suggestions and possible improvements before being released to the public. Below is Lian Li’s press release.
LIAN LI’s 2022 Digital Expo 2.0 Reveals Exciting New Prototypes and Updates
New prototypes for LANCOOL 216, DAN Cases A3 m-ATX, and O11D EVO XL
New prototypes for SL120/140 V2, AL120 V2 and AL140
Update for the UNI FAN P28 with Silent and Performance editions
New in-house designed All-In-One liquid cooler series
Lian Li Digital Expo 2.0
June 30th, 2022, Taipei, Taiwan – LIAN LI Industrial Co. Ltd., a leading manufacturer of aluminum chassis and PC accessories, premieres the LIAN LI 2022 DIGITAL EXPO 2.0 at 9am EST on YouTube (here). The 2-part video series reveals new prototypes of 3 cases, 4 fans, and an All-In-One liquid cooler. The new cases include the LANCOOL 216, DAN Cases A3 m-ATX, and the highly anticipated O11D EVO XL. LIAN LI also presents the next generation UNI FANs with SL120 V2, SL140 V2, AL120 V2, and AL140, including an update of the UNI FAN P28. And the show closes with a new 100% LIAN LI design All-In-One liquid cooler.
LANCOOL 216 The LANCOOL 216 is a mid-tower with excellent cooling and is configurable for air or All-In-One liquid cooling. The rotatable I/O shield enables Upper Motherboard or Air Cooling mode, where the motherboard can be installed higher for extra room for vertical GPUs and larger CPU tower coolers. By rotating the I/O shield 180 degrees, it enables the Lower Motherboard or All-In-One Liquid Cooling mode to support thicker radiators and lengths of up to 360mm. To maximize the air intake and exhaust, an external rear fan 120mm bracket can be installed below the GPU IO ports, and a cover plate can be added on the top to seal off unnecessary openings to reduce air pressure loss.
DAN Cases A3 m-ATX This prototype is the latest collaboration between DAN Cases and LIAN LI. Just under 20 liters with support for up to a 360 radiator, the case features a reversible frame for the option of choosing a left or right orientation. Depending on your configuration, the A3 m-ATX is capable of supporting SFX and ATX PSUs, 4 slot GPUs of up to 380mm in length (horizontal or vertical), up to a 360 All-In-One liquid cooler radiator or a 158mm tall CPU cooling tower, and two 2.5” SSDs. The A3 m-ATX features a 1.5mm thick all-aluminum exterior design on a steel frame 1.2mm thick and the bottom features a beautiful ARGB underglow. An optional side tempered glass panel is available to replace the side mesh panels.
O11D EVO XL The O11D EVO XL is updated with features from the O11D EVO, such as reversible design, multiple I/O module mounting points, and upright GPU support. The O11D EVO XL has a modular rear panel with a removable motherboard tray that combines the I/O shield and expansion slot. This eliminates the need to relocate the motherboard standoffs when moving the motherboard up or down. This motherboard tray can be adjusted to 3 different positions, providing better flexibility for custom water-cooling configurations while maintaining E-ATX support. With the extra room, the O11D EVO XL offers the possibility for extreme cooling and hardware configurations with support for up to 3 x 420mm radiators. The front left frame bar can be removed for an unobstructed view of the system.
NEW UNI FAN SL120/140 V2, AL120 V2, and AL140 The new UNI FAN SL and AL fans will be available in 120mm and 140mm fan sizes. With a thicker frame at 28mm, the SL120 V2 and AL120 V2 deliver better thermal performance with an increase in airflow, static pressure, and even a lower noise level at similar or higher speeds than the original version. The UNI FAN SL120/140 V2 lighting has been updated to provide a smoother finish along the edges and diffuser, and a smaller gap between the diffuser when interlocked (from 2.8mm to 1.5mm). The UNI FAN AL120 V2 and AL140 keep the same AL look at the front and rear with their four thin arcs around the fan edge, but now feature thin RGB lines at each corner of the fan’s side, along the aluminum strip.
UNI FAN P28 SILENT & PERFORMANCE EDITIONS The UNI FAN P28 has been updated with two models: Silent edition, and Performance edition. The P28 Silent is a 120mm PWM fan with speeds of up to 1900 RPM and noise levels of 27.5 dBA, 3.04 mm H2O of air pressure, and 59.97 CFM of airflow. The UNI FAN P28 Silent is an ideal system fan. The P28 Performance is a 120mm PWM fan with speeds of up to 2300 RPM, a maximum of 33 dBA, 3.86mm H2O, and 71.27 CFM. With faster speeds and static pressure, the P28 Performance is optimized for radiators.
NEW All-In-One Liquid Cooler The prototype All-In-One liquid cooler features a 100% LIAN LI design built from the ground up. The new 360 All-In-One liquid cooler comes with a 32mm thick x 130mm wide radiator, and is paired with performance-optimized 28mm thick fans, delivering great thermal performance. The unique pump block design offers a great level of customization with multiple included accessories that allow the user to completely change the lighting style of their pump block, from plain diffused RGB glow to more conservative cover plates, or different levels of infinity mirrors and infinity dotted patterns.
To catch the full 2022 DIGITAL EXPO 2.0, make sure to subscribe to the LIAN LI YouTube channel here.
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Lian Li is known for killer cases. Mostly all aluminum, they can border on works of art. When they approached us about reviewing a benching station it took me by surprise. They have released a couple new benching stations, the PC-Q06 and the PC-T60, the former of which we’ll be sinking our teeth into today.
It has been a long time coming and thankfully this project, Rhapsody in Red (named after a song written & performed by my band in college), is finally complete. Stop in and check out what some great looking fans, cables and a case-matching fan controller can do to really make your build pop!
Today, Lian Li launched the A4-H2O m-ITX chassis in collaboration with DAN cases. This small form factor case measures only 11 liters but can house a 240 mm liquid cooler and a triple slot GPU of up to 322 mm long. Pre-ordering starts today and is available in either black or silver. A PCIe 3.0 or PCIe 4.0 riser cable is included with the purchase. The U.S. MSRP for the PCIe 3.0 version is $129.99 and the PCIe 4.0 version is $164.99. Global pricing varies slightly. Below is Lian Li’s official press release with additional details and links.
There aren't many mATX cases being built these days and this is a nice one. I'm personally not a fan of the mesh side panel but there is a glass side panel option too, so that's cool.
Loading new replies...
1
