Montech just launched the Metal DT24 premium and Metal DT24 Base dual-tower CPU coolers, along with a Metal 120 mm PWM fan. The coolers feature six copper heat pipes measuring six millimeters thick with a fin stack and cooling base made of copper and aluminum. Montech claims an impressive 270 Watt TDP which would make it one of the best Air coolers on the market. The Premium variant receives a decorative top plate and ARGB lighting, while the Base version comes in silver and black without lighting.
The Metal 120 mm PWM fan features Hydro Dynamic Bearings (HDB), providing up to 400,000 hours of quiet operation. It has a maximum speed of 1950 RPM, which generates a rated 69 CFM and 2.82 H2O of static pressure. It accomplishes this while only creating 26 dBA. These are very lofty specifications.
Montech has provided links for additional information and to purchase in its press release listed below.
MONTECH Launches High-performance METAL DT24 CPU Coolers and METAL 120 PWM Fan
METAL DT24 BASE and PREMIUM CPU Coolers –Dual tower, for a total of 104 fins to maximize surface area to 8553.23 cm2 – 6mm thick copper x 6 heat pipes – Includes 2x METAL 120 PWM fans – Supports up to 270 Watt TDP – METAL DT24 BASE, available at MSRP US$57 – METAL DT24 Premium, with aluminum ARGB top cover, available at MSRP US$69
METAL 120 PWM fan –Unique Airfoil fan blade with high airflow and static pressure design – Industrial-grade 6-pole motor – Hydro Dynamic Bearing (HDB) with 400,000 hours lifespan – Max speed of 1950RPM with 69 CFM airflow, 2.82mm H2O static pressure – Quiet operation at max 26 dBA – Available at MSRP US$9.90
November 30th, 2022, Taipei, Taiwan – MONTECH, an innovative PC components and peripherals brand, announces the Metal DT24 BASE and DT24 PREMIUM, dual tower CPU coolers equipped with 2x METAL 120 PWM fans. Featuring a 104-fin stack paired with 6 heat pipes of 6mm diameter each, the METAL DT24 is compatible with the newest INTEL LGA 1700 and AMD AM5 socket with a rated TDP of 270W. The DT24 PREMIUM includes an additional aluminum ARGB top cover. The included METAL 120PWM fans offer speeds of up to 1950 RPM and deliver up to 69CFM of airflow and 2.82mm H2O of static pressure at a 26 dBA noise level. The METAL DT24 BASE is available at MSRP US$57.00, the METAL DT24 PREMIUM is available at MSRP US$69, and the METAL 120 PWM is available at MSRP US$9.90.
Montech DT24
High-Performance CPU Coolers – METAL DT24 The dual-tower, dual-fan METAL DT24 CPU coolers are built from the ground up for high-performance cooling. The heatsink includes a total of 6x 6mm thick heat pipes for quick and efficient heat transfer from the CPU. The dual-tower cooler has a massive 104-fin stack, which gives the METAL DT24 a surface area of 8553.23 cm2 allowing the cooler to handle up to 270W TDP. The METAL DT24 supports the latest Intel LGA 1700 and AMD AM5+ processors.
Montech DT24
Performance with or without ARGB The METAL DT24 is available in BASE or PREMIUM versions. The Metal DT24 PREMIUM includes an additional aluminum ARGB top cover that provides a sleek all-black aluminum cover with ARGB diffuser strip wrapped around the edges. The Metal DT24 PREMIUM top cover adds a mere 5.3mm to the total height of the CPU cooler and is powered by a 5 volts 3-pin ARGB header. It is compatible with all motherboard lighting software.
Montech DT24
High-performance Fans & Ultra Durable at 40,000 Hours MTTF The two included Metal 120PWM fans are designed with all-black Airfoil fan blades for exceptional airflow and static pressure. Equipped with an industrial-grade 6-pole motor design for extra durability and use high-quality HDB (Hydro Dynamic Bearing) to reach MTTF 40,000 hours. The fan runs at speeds of 800 to 1950 RPM, the METAL 120 PWM fan can output 69 CFM airflow and 2.82mm H2O static pressure at a low 26 dBA noise level. The Metal 120 PWM fans are also sold separately at US$9.90.
Montech Metal Fan
Pricing & Availability The MONTECH METAL DT24 and METAL 120 PWM are available at AMAZON.
METAL DT24 BASE: $57.00 METAL DT24 PREMIUM: $69.00 METAL 120 PWM: $9.90
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Enermax introduces an inexpensive case, the COENUS. Where did they get that name? According to Wikipedia, “Coenus (in Greek Koῖνος; died 326 BC), a son of Polemocrates and son-in-law of Parmenion, was one of the ablest and most faithful generals of Alexander the Great in his eastern expedition.” With a warrior’s helmet in the logo, they were clearly referring to that kind of excellence. Is this case “one of the ablest?” Let us see.
I have seen it talked about on the forums that the Corsair Hydro Series H50 low cost water cooling system is equal or better than high end air, with some heated discussions taking place at time from people arguing for or against that statement. So, since Corsair was kind enough to send us an H50 system for testing, I decided to see if the H50 can equal some of the best air cooling solutions on the market.
We use cookies to ensure that we give you the best experience on our website. If you continue to use this site we will assume that you are happy with it.OkPrivacy policy
Loading new replies...
Dreadnought Class Senior
Powder Junkie Moderator
