Table of Contents
Today, the MSI MEG Z690 ACE is our test bench’s DDR5 LGA 1700 motherboard. The Z690 ACE is one classy-looking motherboard forgoing any onboard RGB LED and covered in so many heatsinks it has a real heft to it. MSI has thrown everything into this board, including the kitchen sink.
Micro-Star International (MSI) is not a new name in the PC enthusiast market. Established in 1986 in Taiwan, they produced mainly motherboards and graphics cards. Today MSI has expanded into the gaming market with its own “Gaming” line of PC components, laptops, monitors, coolers, and peripherals. They also have their hands in robotic automation, industrial-grade servers, and the automotive industry with a global presence in over 120 countries.
The MEG series from MSI sits at the high end of their product lines, and they typically include features that justify that position. The z690 ACE we have here today is no exception with 24K gold accents, onboard Thunderbolt 4, and very well equipped to handle any Alder Lake CPU so let’s dive in.
Specifications and Features of the MSI MEG Z690 ACE
Coming back to reality, we have today’s test subject, the MEG Z690 ACE listing at $550. MSI still divides its motherboards into series starting at the top of the heap; we have the MEG, followed by MPG, MAG, and then the PRO series. As we mentioned earlier, the MSI MEG Z690 ACE is part of MSI’s MEG series. There are currently five Z690 motherboards in this series, all of which are DDR5 offerings. Starting at the top, we have the MEG Z690 GODLIKE, an exclusive $2100 motherboard that includes 32 GB of Kingston DDR5 and a 360 mm all-in-one liquid cooler. Suppose you hope to acquire one of these motherboards; you first need to register with MSI. Moving down the stack, we have the MEG Z690 UNIFY-X for $500, the Z690 UNIFY at $430, and the mini ITX Z690I UNIFY for $400.
The MSI MEG Z690 ACE supports the twelfth generation Intel processors using the LGA 1700 socket. The board boasts a 22-phase (19+1+2) VRMS to handle the power requirements of the flagship 24-thread Intel Core i9-12900K. To cool the VRM, MSI uses two large milled aluminum heat sinks connected with a heat pipe. We have 7 W/mK thermal pads on the MOSFETs and the chokes to ensure good contact and heat dissipation. Also helping with heat dissipation is an 8-layer PCB made from IT-170 server-grade PCB material and 2 oz thickened copper.
The MEG Z690 ACE has four DIMM slots that support up to 128 GB of dual-channel non-ECC, unbuffered memory with speeds of 6666 MHz. We can find 6666 MHz rated kits on the QVL in single-rank Hynix options from ADATA.
For PCIe, we have three full-length PCIe x16 slots, of which only the top one is x16 electrically; we have supplied a bandwidth breakdown in the table below. The upper two slots (from CPU) will run in PCIe Gen 5.0 mode (x16/x0, x8/x8), and the lowest full-length PCIe slot (from PCH) are Gen 4.0×4 and shares bandwidth with the M.2 slot directly above it. All three full-length PCIe slots feature MSI’s PCI Express Steel Armor technology for added strength with reinforced, heavy solder points and EMI shielding for signal integrity.
On the storage front, the MPG Z690 EDGE comes with six SATA 6 Gb/s ports, four from the PCH that support RAID 0, 1, and 10, and two additional ports from an ASMedia ASM1061 controller. On the M.2 side, MSI has included five sockets on the ACE. All five sockets support PCIe NVMe drives. The lowest two M.2 (Key-M) will support PCIe NVMe and SATA-based M.2 drives; using a SATA-based drive in the fifth M.2 slot will disable the seventh SATA 6 Gb/s port. All of the M.2 drive slots come with integrated heat spreaders. Refer to the table below or the user manual from MSI’s website for more details of the storage layout and drive compatibility.
USB connectivity is also plentiful on the MEG Z690 ACE, with 18 possible connections between onboard headers and the rear I/O shield. The rear IO shield has seven Type-A ports and one Type-C, all of which are USB 3.2 Gen2 (10 Gbps). The remaining USB connections are headers on the motherboard consisting of two USB 2.0 (for four ports), two USB 3.2 Gen1 (for four ports), and two USB 3.2 Gen2x2 Type-C (20 Gbps) internal headers.
Another significant feature of the MSI MEG Z690 ACE is the inclusion of Thunderbolt4 located on the IO shield. Here we have two USB Type-c connectors that support up to 40Gbps transfer rate with Thunderbolt devices. We also have two mini display port input headers that support up to 8K display using the DisplayPort of the discrete graphics card connected as a passthrough.
On the Z690 ACE, we have a typical Z690 motherboard layout on the networking front offering dual Intel I225-V 2.5 Gbs ports. We also have Intel Wi-Fi6 / Bluetooth 5.2 wireless connectivity out of the box with an included Wi-Fi antenna that connects at the rear I/O shield.
MSI chose the Realtek 7.1 channel High Definition ALC4080 processor with S/PDIF and an ESS SABRE9018Q2C AMP/DAC on the audio side. With MSI’s Audio Boost 5, we also have PCB optimizations such as an isolated audio section to eliminate EMI, separate layers on the board for left and right audio channels, and premium Japanese-made Nippon Chemicon audio capacitors.
Rounding things off, MSI has chosen not to add RGB LED into the ACE as we typically see these days. Instead, MSI has decided to let the golden elegance of the ACE speak for itself. There is still a variety of RGB LED connectivity, such as one standard 4-pin RGB LED header for 12 V, 5050 RGB strips up to 3 A, and two 3-pin Rainbow LED addressable RGB headers for 5 V WS2812B individually addressable LED strips with a rating of 3 A. The ACE also incorporates a Corsair RGB LED link connection and an EZ LED Control switch; all the headers are in your control using Mystic Light software.
Below is the specification list from the MSI MEG Z690 ACE webpage.
MSI MEG Z690 ACE Specifications | |
CPU | Support for 12th Generation Intel Core i9/ i7/ i5/ i3 processors and Intel Pentium processors/ Intel Celeron processors in the LGA1700 package |
Chipset | Intel Z690 |
Memory |
Expansion Slots |
Multi-GPU |
Storage |
LAN | 2x Intel I225V 2.5Gbps LAN controller |
Wi-Fi |
Audio | Realtek ALC4082 Codec + ESS SABRE9018Q2C Combo DAC/HPA
USB |
Thunderbolt 4 | Intel JHL8540 Thunderbolt 4 Controller
Fan Headers |
OS Support | Supports Windows 11 64 bit |
Form Factor | E-ATX |
Price | $599.99 at Newegg.com |
We have also included a list of features sourced from the MSI website for the MEG Z690 ACE:
MSI MEG Z690 ACE Features | |
DIRECT 19+1+2 PHASES POWER DESIGN Unleash and sustain the maximum performance with a flagship VRM design built with a total of direct 19+1+2 digital power phases. Combining dual power connectors and 105A Smart Power Stage, MEG Z690 ACE is ready for the challenge of high-end processors. | |
LATEST DDR5 MEMORY A considerable step for DDR performance enhancement with the latest DDR5 memory. Combined with a dedicated SMT welding process and MSI Memory Boost technology, MEG Z690 ACE is ready to deliver world-class memory performance. | |
PCB DESIGN The PCB design has been optimized for higher bandwidth and faster transfer speeds, which is also beneficial for reliable circuit transmission.
CORE BOOST Core Boost technology combines MSI’s premium layout and digital power design, which allows for faster and undistorted current delivery to the CPU at pinpoint precision. Not only supporting multi-core CPU but also creating the perfect conditions for your CPU overclocking. | |
DIGITALL POWER DESIGN A fully digital power design allows for faster and undistorted current delivery to the CPU at pinpoint precision. Creating the perfect conditions for CPU overclocking. | |
OVERVOLTAGE PROTECTION It prevents potential short-circuit damage to the CPU and other critical components. | |
DUAL THUNDERBOLT 4 PORTS Experience Thunderbolt 4 with unprecedented interface bandwidth speeds up to true 40Gbp and support for up to six daisy-chained devices. Additionally, Maximum 8K display support, Multi-Port Accessory Architecture, and USB 4.0 compliant provide reliable connectivity and better user experience. | |
DUAL FRONT USB 3.2 GEN 2X2 20G TYPE-C Front USB devices have never been faster! MEG Z690 series motherboards offer a wide variety of options to connect and boost your USB devices, offering never-before-seen USB speeds up to 20Gb/s when connecting the front USB Type-C. | |
SURFACING WITH THE REAL MU-MIMO TECHNOLOGY The latest Wi-Fi 6E solution supports 6GHz spectrum, Bluetooth 5.2, two-way MU-MIMO, and BSS color technology, providing up to 4X network capacity and efficiency in the high signal density environment, delivering speeds up to 2400Mbps. | |
FORTIFY YOUR SYSTEM WITH PCI-E STEEL ARMOR MSI PCI Express Steel Armor slots are secured to the motherboard with extra solder points and support the weight of heavy graphics cards. When every advantage in games counts, Steel Armor shields the point of contact from electromagnetic interference. |
Retail Packaging and Accessories
We have the motherboard name and series on the front of the retail packaging and a nice closeup of the MEG Z690 ACE. There isn’t much detail on the front; however, turning over the box exposes more information around the ACE’s general layout and features. We have a picture of the board and the rear I/O showing the connections giving a good overall description of what’s inside.
The packaging is typical, with the motherboard in an anti-static bag nestled into a form-fitting tray. MSI has included a few extras for accessories like two DP to mini DP cables for the Thunderbolt 4 passthrough, two thermistors, and a nice soft cloth to keep that gold fingerprint free. You can find these accessories in another cardboard tray under the motherboard tray.
Included accessories:
Below is a slideshow of the retail packaging and accessories.
Meet the MSI MEG Z690 ACE
The Z690 ACE has an overall dark theme suitable for most PC builds. It builds around a jet-black PCB, and MSI has chosen to use black with 24K gold accents for all heat sinks and cladding. The I/O cladding also features the MSI Gaming dragon logo adorned in gold. We have MEG etched into the upper heat sink and the “ACE” model name on the large VRM heat sink to the right.
Turning the board over, MSI has added a large aluminum heatsink for power section cooling. The heatsink also has thermal tape applied directly behind the VRMs for maximum dissipation to the backplate.
A Closer Look at the MEG z690 ACE
Starting at the left is a large shroud covering the I/O. Unlike most, this shroud doesn’t have any of the RGB LEDs we find on most motherboards. Instead, MSI has used a mesh design with a 24K gold MSI Gaming dragon. The mesh shroud and the large VRM heatsink with its large 24K gold stripe are aluminum for maximum heat dissipation. We also have a smaller heat sink for the upper VRM connected via a heat pipe with the “MEG” series in gold.
The dual 8-pin EPS connectors have been moved from their usual position and relocated above the four DIMM slots. In theory, this should aid in cable management behind the motherboard tray. Across the top are PWM fan connectors for CPU (2 A) and Pump ( 3 A), and in the corner is the Debug Code LED. There’s a Rainbow LED header with voltage read points next to it down the right side. , Then we have a Corsair link header, the EZ Debug LEDs for troubleshooting, and a 2 A system fan header. The top section of the ACE is the 24-pin ATX power connector, two USB 3.2 Gen2x2 Type-C headers, and two USB 3.2 Gen 1 headers. You’ll also notice a large piece of metal here, which isn’t a heat sink. Its purpose is to stiffen the motherboard and prevent flexing when installing memory or the 24-pin ATX power connector.
The lower half of the MEG Z690 ACE contains all the storage, PCIe expansion, PCH, and audio. Located on the far left of the motherboard is a Realtek ALC4082 codec that drives the 7.1 channel HD audio. We also have the Nippon Chemicon caps and an ESS SABRE9018Q2C DAC/AMP for premium sound quality and immersive gaming.
Moving into the PCIe area, we find the five M.2 sockets that support RAID 0, RAID 1, RAID 5, and RAID 10. The top M.2 slot can accommodate up to 110 mm (Type 22110) PCIe Gen4.0 x4 NVMe drives and connects via the CPU: the remaining four M.2 slots’ bandwidth comes from the PCH. The second and third M.2 slots accept 80 mm NVMe drives and run at PCIe Gen 4.0 x4 and PCIe 3.0 x4, respectively. The lowest two take both PCIe 4.0 X4 and SATA-based M.2 SSDs on the ACE, using a SATA-based drive in the fifth M.2 slot will disable SATA_6G port number seven.
The Z690 ACE has three full-length PCIe slots, and they all have MSI’s PCIe Steel Armor for added strength and signal clarity. The two upper slots are connected directly to the CPU, sharing the total bandwidth of PCIe Gen 5.0 in an x 16/ x0 or x8/ x8 if both slots are populated. The remaining full-length slot gets its bandwidth from the chipset with a maximum PCIe 4.0 x4 speed. This slot shares bandwidth with the fourth M.2 slot; if both are populated, the PCIe slot drops to PCIe 4.0 x1, and the M.2. drops to PCIe 4.0 x2. The ACE also supports Nvidia’s SLI and AMD’s Crossfire technology for multiple GPUs.
Moving to the right is the Z690 chipset covered by a good-sized heatsink with the M.2 Shield Frozr heatsinks interconnecting with it. Six SATA 6 Gb/s ports labeled from the top down 6/5, 8/7, and B/A. Only four SATA 6 Gb/s get bandwidth from the PCH and support RAID functionality. The lower two ports labeled “A” and “B” use an ASMedia ASM1061 controller and do not support RAID.
Across the bottom are a ton of headers. Of note, here are some extras not usually found as jumpers on a motherboard. MSI has included some extreme OC options typically used when using LN2 (liquid nitrogen) for cooling. These jumpers are located above the Power and Reset buttons and consist of LN2, Slow Mode, Safe Mode, and OC Retry jumpers. We’ll just put the remainder in a bulleted list for ease of reading (from Left to Right).
- Front Panel Audio
- One RGB LED header
- 2x Thermal Sensor Connectors
- Water Flow Meter Connector
- PWM System Fan (2A) x 5
- BIOS Switch
- LED On/Off Switch
- USB 2.0 header x 2
- Reset and Power Buttons
- Trusted Platform Module Header
- Tuning Controller Connector
- System panel header
- ARGB connector
- Clear CMOS Jumper
Moving around to the rear I/O area, we see MSI has included a pre-installed I/O shield, which seems pretty standard these days. Starting from the left, we have a clear CMOS button and a BIOS flash button that enables a BIOS update with only power to the board needed; CPU and memory are unnecessary. You will need a formatted flash drive in FAT32 and rename the BIOS file to MSI.ROM and save it to the root directory of the flash drive. A specific USB port is used for this and labeled as such.
Next to the flash button are two Intel 2.5 Gbps LAN ports and seven USB 3.2 Gen2 (10 Gbps) ports. Next to the BIOS Flash button, the ACE has one USB 3.2 Gen2 Type-C port that supports Display Port 1.4 video out with HBR3 (High Bit Rate 3) and a maximum resolution of 4K 60Hz. Directly above this is a USB Type-A that for BIOS flashing as mentioned above.
Next, we have dual Thunderbolt 4 (40 Gbps) USB Type-C ports and two mini display ports for video passthrough using the Thunderbolt 4 ports; this requires a discrete GPU connected with the supplied cables. We have the integrated Wi-Fi antenna connections, and on the far right are the audio jacks with Optical S/PDIF Out.
Moving to the opposite corner of the Z690 EDGE DDR4 motherboard are the SATA 6 Gb/s ports. The chipset controls the four SATA 6 Gb/s ports to the right labeled 5 to 8 and supports RAID 0, 1, and 10. The last two ports labeled “A” and “B” run through an ASMedia ASM1061 controller and do not support RAID.
Last up, we have the heatsinks installed on the MEG Z690 ACE. MSI has included their M.2 Shield Frozr heatsinks pre-installed thermal tape to help keep your storage cooler. The VRM section has finely machined heatsinks connected by a heat pipe. Both pieces have thermal tape for the MOSFETS and the chokes with good contact, as you can see in the pics below. MSI has also equipped the ACE with a backplate and thermal tape to aid in heat dissipation from the power section. It also protects the back of the motherboard from accidental damage during installation.
The power section on the z690 EDGE consists of a 19+1+2 phase configuration. Power comes to the board via the dual 8-pin EPS connectors feeding a 20-phase Renesas RAA229131 digital PWM controller. Power is routed directly into 19, 105 A, Dr.MOS type Renesas RAA 22010540 MOSFETS. They terminate with MSI’s Titanium Choke III and long-life capacitors for a high-quality power delivery system. This setup provided ample power for our i9 12900K at 5.2 GHz.
Below are images of some of the ICs found on the board.
Below is a picture of the MSI MEG Z690 ACE on the test bench.
UEFI BIOS and Overclocking Software
MSI MEG Z690 ACE BIOS
The MSI MEG Z690 ACE uses MSI’s Click BIOS 5, offering an EZ mode and an Advanced mode accessible using F7. EZ mode displays all pertinent system information and allows access to the most commonly used options with the click of the mouse. We can set the XMP for the RAM and access the BIOS update tool from this page.
After switching to advanced mode, the BIOS access consists of six sections: Settings, OC, M-Flash, OC Profile, Hardware Monitor, and Beta Runner. Most users will head right for the OC section, where you’ll find the majority of settings you will need for overclocking. Including P-Core, E-Core, and Cache multipliers, all relative voltages, and DRAM settings. Some subsections are worth mentioning within the OC section, such as the DRAM configuration, which contains detailed options for the primary, sub, and advanced timings and latency and termination configurations. We also have the CPU Configuration section containing the Intel Turbo options, power limit overrides, and Per Core control. Over-current, over-voltage, and load line calibration controls are all located in the Digitall Power section.
If you can’t find it in the OC section, head to the Settings section, as you’ll most likely find it here. We see the Boot settings, Save & Exit, and Advanced subsections here. The Advanced subsection has the remaining system control settings for storage, USB, and Power Management, to name a few.
Overall the BIOS was easy to navigate, and nearly everything needed for overclocking was accessible through the OC section or subsections.
Below is a slideshow of the remainder of the BIOS.
Overclocking/Monitoring Software – MSI Center
MSI has moved to an all-in-one Overclocking/hardware monitoring software now called MSI Center. Once you have MSI Center installed, it offers a variety of optional apps to install from a single platform. The software is easy to navigate and works well. All overclocking settings are now located in the “User Scenario” section offering three presets and a custom profile. The custom profile is where you go for manual software overclocking. It’s divided into sections separating the multipliers and voltages and took effect without requiring a reboot. We also have the Frozr Ai for adjusting cooling profiles and the Mystic Light section for your RGB LED customization.
Test Setup and Performance of the MSI MEG Z690 ACE
Test System and Procedure
Since we’re known for overclocking and benchmarking, we take a different approach to CPU testing using several Hwbot.org benchmarks. We also do some real-world testing with Cinebench, Blender, Corona, and 7Zip to give readers a good idea of the general performance.
Test System Components | |
Motherboard | MSI MEG Z690 ACE |
CPU | Intel Core i9-12900K |
CPU Cooler | EK-XLC Predator 360 AIO |
Memory | 2×16 GB Kingston Fury 5200 MHz CL40-40-40-79 |
SSD | Gigabyte Aorus 2 TB NVMe Gen4 (OS + Applications) |
Power Supply | EVGA 750 W G3 |
Video Card | MSI RX 6900 XT Gaming X Trio |
Operating System | Windows 11 Pro x64 |
We’ll perform our usual set of benchmarks which test rendering, memory performance, and single/multi-threaded CPU performance. For 2D benchmarks, we use SuperPi 1M and 32M and WPrime and Cinebench R23 and CinebenchR20 for rendering comparisons. We test our memory performance with AIDA64 Cache and Memory benchmark. We use Blender and Corona for encoding and a more real-world test in 7zip. The CPU is at stock speeds (set BIOS optimized defaults, XMP only, no MCE). Memory speed is 5200 MHz Gear2 using the XMP profile of the Kingston Fury Beast DDR5.
Also, with the new Alder Lake systems, we have noticed the motherboards tend to let things run free with excessive voltage when left on auto settings, so good cooling is a must. For comparison, we have also included our overclocked performance data with the CPU at 5.2 GHz on all P-Cores with E-Cores at 4.1 GHz.
Memory Performance Tests
AIDA64 – Memory Bandwidth and Throughput
AIDA64 Cache and Memory Benchmark
AIDA64 Cache and Memory Benchmark – Raw Data | ||||
Motherboard | Read | Write | Copy | Latency |
MSI MEG Z690 ACE | 81269 | 74160 | 74362 | 82.3 |
MSI MPG Z690 EDGE WIFI DDR4 | 57855 | 52953 | 56709 | 53.7 |
BIOSTAR Z690A Valkyrie | 57380 | 52842 | 55855 | 59 |
MSI PRO Z690A (DDR5) | 69231 | 66523 | 68386 | 82.6 |
AIDA64 – CPU Tests
AIDA64 CPU Benchmark – Raw Data | |||||
Motherboard | Queen | Photo | ZLib | AES | SHA3 |
MSI MEG Z690 ACE | 115688 | 50410 | 1597.6 | 207213 | 6006 |
MSI MPG Z690 EDGE WIFI DDR4 | 115038 | 30741 | 1584.7 | 206371 | 5998 |
BIOSTAR Z690A Valkyrie | 113320 | 31629 | 1604.8 | 205218 | 5838 |
MSI PRO Z690A (DDR5) | 111826 | 45415 | 1592.8 | 205545 | 5898 |
AIDA64 – FPU Tests
AIDA64 FPU Benchmark – Raw Data | ||||
Motherboard | FP-64 | Julia | Mandel | SinJulia |
MSI MEG Z690 ACE | 130452 | 64559 | 14688 | 14706 |
MSI MPG Z690 EDGE WIFI DDR4 | 130616 | 66253 | 14626 | 14878 |
BIOSTAR Z690A Valkyrie | 129475 | 65486 | 14671 | 14210 |
MSI PRO Z690A (DDR5) | 130196 | 65734 | 14602 | 14589 |
Our memory tests show that the different RAM generations make little difference in the CPU and FPU tests aside from Photoworx, which benefits from the extra bandwidth. The Kingston 5200 MHz DDR5 also had an advantage in the memory benchmark with increased bandwidth but sacrificed latency by nearly 30 ns compared to the EDGE. Looking at the two DDR5 options, the MPG Z690 ACE pulled ahead in most tests, but the gains are marginal.
Real-World Tests
Cinebench R11.5/R15, POVRay, x265 (HWBot), 7Zip – Raw Data | ||||
Motherboard | R20 | R23 | Corona | 7Zip |
MSI MEG Z690 ACE | 10557 | 27657 | 8852750 | 129866 |
MSI MEG Z690 ACE OC | 11342 | 29786 | 9365990 | 134518 |
MSI MPG Z690 EDGE WIFI DDR4 | 10430 | 27239 | 9130360 | 106118 |
BIOSTAR Z690A Valkyrie | 10274 | 26977 | 9138770 | 105238 |
MSI PRO Z690A (DDR5) | 10473 | 27443 | 8704170 | 126851 |
The results above are interesting; DDR5 only seemed to have an advantage in 7 Zip, thanks to the added bandwidth. It also appears that the Corona rendering engine gets a boost from the lower latency of the DDR4 platforms.
Pi and Prime Based Tests
SuperPi and wPrime Benchmarks – Raw Data | |||||
Motherboard | Spi 1M | SPi 32M | WPrime 32M | WPrime 1024M | Blender |
MSI MEG Z690 ACE | 7.035 | 361.585 | 2.109 | 43.061 | 128 |
MSI MEG Z690 ACE OC | 7.01 | 360.785 | 1.968 | 40.841 | 119 |
MSI MPG Z690 EDGE WIFI DDR4 | 7.036 | 360.866 | 2.131 | 45.242 | 127 |
BIOSTAR Z690A Valkyrie | 6.89 | 361.026 | 2.116 | 151.434 | 127 |
MSI PRO Z690A (DDR5) | 6.968 | 367.633 | 2.187 | 148.215 | 128 |
All of the tests above have very similar results regardless of the memory type. Performance may change if we were using faster DDR5 with tighter timings, but as it stands, the middle-of-the-road DDR5 doesn’t appear to offer much of an advantage at this time.
I would also like to note the odd results in WPrime 1024. Since we first started testing the new Alder Lake CPUs, the WPrime 1024 results seemed a bit off now with some updates, and they’re more in line with what we were expecting.
Gaming Tests
We have updated our gaming tests and dropped them down to four games for motherboard reviews. In many cases, the difference between boards isn’t that much, and the titles we use to cover both CPU-heavy and GPU-bound titles. All game tests were run at 1920×1080 and 1440×2560 with all CPUs at default settings unless otherwise noted. Please see our testing procedures for details on in-game settings.
- Shadow of the Tomb Raider – DX12, “Highest” preset
- Far Cry 6 – DX12, Ultra preset, VSync Off
- F1 2021 – DX12, Very High defaults, TAA, and x16 AF, Bahrain track, show FPS counter.
- Metro: Exodus – DX12, Ultra defaults
- UL 3DMark Fire Strike (Extreme) – Default settings
Gaming Results
As with the 2D benchmark results we saw previously, the gaming benchmarks were similar regardless of the RAM settings. However, it does appear that the same updates did help in some of our game titles, specifically Far Cry6, where the 12900K got nearly a 20 FPS increase since we first started testing in November.
The 1440p results are pretty typical as this resolution relies more on the GPU than the CPU.
3DMark Results
The 3DMark Firestrike results are very similar across the board as well.
Power Consumption
As was mentioned earlier, the 12900K tends to get a bit more voltage than necessary at stock. Comparing the stock and overclocked settings, we can see the power usage did increase when overclocked but not significantly. Looking at Blender, we only needed an extra 35 W to run the benchmark at 5.2 GHz on the P-Cores and 4.1 GHz on the E-Cores.
The temperatures below also didn’t show a significant change when overclocked.
Temperatures
Overclocking with the MSI MEG Z690 ACE
Overclocking on the MEG Z690 ACE was pretty straightforward as far as the BIOS was concerned: select the multiplier and adjust the voltage to compensate. However, we used a different cooler this time than our previous reviews. The EK Predator is a bit older and needed the LGA1700 backplate upgrade, free from EK aside from shipping costs, but it did outperform the Ryujin we were using previously. The result was an all-P-core overclock of 5.2 GHz with the E_Cores at 4.1 GHz, pushing our CB R23 results to nearly 30K. You’ll find the overclock performance numbers in the graphs above. We did have a bit of cooling headroom left, but a few quick attempts at 5.3 GHz weren’t successful, and time is limited.
Overclocking using the Turbo Offset
We tried an option in the BIOS that allows users to set an offset for the turbo bins on the Alder Lake CPUs. As the screenshots below show, it does work, but starting a stability test caused the CPU to overheat immediately. We used a +3 offset, so all-core boost should, in theory, reach 5.2 GHz and single-core 5.5 GHz. We managed 5.5 GHz in SuperPi, a single thread benchmark, but running Cinebench R23, the maximum speed attained was 5.1 GHz. This lower speed would have been caused by throttling as the CPU voltage would climb over 1.4 V hence the instant overheating during stress testing. With some voltage manipulation in BIOS, this could be a viable alternative to manual overclocking.
Conclusion
The MSI MEG Z690 ACE is well equipped for a motherboard in its price range and has a lot to offer any user. The ACE has a solid 19+1+2-phase power section, 8-layer server-grade PCB, and more than adequate heatsinks. There are five M.2 sockets, six SATA ports on the data storage front, and 18 possible USB connections. The lack of RGB lighting is an excellent option to have available, and it does come with RGB and ARGB headers and an On/Off switch to control lighting extensions.
Overclocking on the ACE was a breeze. The BIOS was easy to navigate, and the board handled itself very well overall. We weren’t disappointed with the overclocking headroom, managing a 5.2/4.1 GHz all-core overclock. As for stock operation, it pays off to take the time to reduce the voltage allowing it to run much cooler with better power efficiency.
On the memory side, the ACE can run up to 128 GB of DDR5 and does well running 32 GB DDR5 5200 MHz at XMP without any extra tweaking in the BIOS. It also has compatibility for RAM up to 6666 MHz; sadly, we don’t have any memory capable of testing this currently.
We can find the MEG Z690 ACE online, currently priced at $599 on Newegg.com, with one offering at $569. There’s a fair amount of competition in this price range. A quick search on Newegg found that the ASRock Z690 TAICHI, the GIGABYTE Z690 AORUS MASTER, and the ASUS ROG Maximus Z690 HERO all carry similar options. Still, the ACE does offer a bit more storage and Thunderbolt 4 passthrough. The Z690 ACE is an elegant-looking motherboard with 24k gold accents. It is right at home in the gaming and overclocking arena. Overall, the ACE gives you everything the Z690 platform offers and more at a reasonable price considering all its options.
– Shawn Jennings (Johan45)
Loading new replies...
Benching Team Leader
