Table of Contents
Noctua recently released the NH-P1 passive CPU cooler and NF-A12x25 LS-PWM low-speed 120mm fan. The much anticipated passive cooler is designed to cool modern high-end processors using only natural heat convection or typical case airflow using its six heat pipes and loads of engineering. The NF-A12x25 LS-PWM fan is designed to assist the cooler in a semi-passive configuration. The PWM function allows the fan to stop during lower loads or rotate up to 1200 RPM under high loads. At full speed, it produces only 12.1 dB. The NH-P1 cooler is listed for $109.90 while the A12x25 LS-PWM fan is $29.90 and is currently available through Amazon. Here is the press release for Noctua.
Noctua introduces NH-P1 passive CPU cooler and LS-PWM fan for semi-fanless systems
Vienna, June 15th 2021 – Noctua today released its much anticipated NH-P1 CPU cooler as well as the optional NF-A12x25 LS-PWM 120mm fan. Custom-designed for fanless operation from the ground up, the NH-P1 is capable of cooling modern high-end CPUs with low to moderate heat dissipation completely passively in enclosures with good natural convection. For further enhanced performance or semi-passive setups that only spin up their fans when necessary, the NH-P1 can be outfitted with a low-speed, ultra-quiet 120mm fan such as the new NF-A12x25 LS-PWM.
“The NH-P1 is our very first passive cooler, and it should be easy to see that we didn’t just take a regular heatsink and omit the fan”, says Roland Mossig (Noctua CEO). “A lot of engineering work went into designing this unit for fanless operation from the ground up and we’re truly proud of the end result. In our completely fanless demo system, the NH-P1 cools an Intel Core i9-11900K running Prime95 at more than 3.6GHz – this is a lot of processing power and a whopping 125W kept in check with zero fan noise!”
The NH-P1 isn’t just a regular heatsink without a fan: featuring much thicker, much more widely spaced fins, it achieves both the mass and the minimal airflow resistance that are required in order to excel in natural convection cooling. In fully optimised fanless systems, the NH-P1 is capable of cooling high-end CPUs with low to moderate heat dissipation using natural convection only (see setup guidelines and CPU compatibility list). This makes it ideal for powerful builds that have no moving parts and run absolutely silent. Topped off with the new, Torx-based SecuFirm2+ mounting system, Noctua’s award-winning NT-H2 thermal compound and a 6-year manufacturer’s warranty, the NH-P1 is the ideal cornerstone for premium-grade fanless or semi-passive builds.
“While we’re very excited about the possibilities that the NH-P1 opens up, we also need to stress that building a passively cooled system is not as straightforward as building a regular system. For optimal results, components must be selected more carefully, and certain principles should be respected”, Roland Mossig (Noctua CEO) explains. “Therefore, we offer detailed setup guidelines, a build guide video tutorial, a list of recommended cases as well as an extensive CPU compatibility list that will help customers to get the best possible results.”
In addition to the NH-P1, Noctua released the optional NF-A12x25 LS-PWM 120mm fan, a low-speed, PWM-enabled variant of the award-winning NF-A12x25 that is ideal for enhancing the performance of the NH-P1 in semi-passive systems. At a maximum noise level of only 12.1dB(A), the NF-A12x25 LS-PWM is nearly inaudible but will still significantly boost the performance headroom of the cooler. As the fan stops at 0% PWM, it can easily be set up for semi-passive operation so that it will only spin up when necessary. This way, the system will work fanless most of the time but still provide the flexibility to make better use of the turbo modes of more powerful CPUs that require some extra airflow to be cooled adequately under full load conditions.
Links
NH-P1
NF-A12x25 LS-PWM
Build guide video
Setup guidelines
List of recommended casesSuggested retail prices
The manufacturer’s suggested retail prices are EUR/USD 109.90 for the NH-P1 and EUR/USD 29.90 for the NF-A12x25 LS-PWM.Availability
Both the CPU cooler and the fan are available as of today via Noctua’s official Amazon stores:Buy NH-P1
Buy NF-A12x25 LS-PWMIn the UK, the products are available as of today through QuietPC. Other sales partners will receive stock shortly.
About Noctua
Designed in Austria, Noctua’s premium cooling components are internationally renowned for their superb quietness, exceptional performance and thoroughgoing quality. Having received more than 6000 awards and recommendations from leading hardware websites and magazines, Noctua’s fans and heatsinks are serving hundreds of thousands of satisfied customers around the globe.
Recent News
Loading new replies...
AKA: JrMiyagi
Benching Team Leader
