Phanteks has just announced its Glacier G40 ASUS Strix/TUF water block for the new RTX 4090 and 4080 GPUs. The full-cover copper cold plate is designed to cool the entire GPU including the memory and power delivery components. The addressable RGB lighting looks fantastic through the clear acrylic top. The location of the fittings has also been revamped to assist hose routing as the 4000 series GPUs are incredibly large. The new blocks are available in satin black for $249.99 or your choice of chrome or matte white for $269.99 on the Phanteks website. Below is Phanteks’ press release.
Phanteks Releases ASUS GPU Water Blocks with New Features
Rotterdam, The Netherlands – October 26th, 2022 – Phanteks announces the release of the new Glacier G40 ASUS GPU block, designed specifically for the ASUS STRIX/TUF RTX 4090/4080 Series cards. The Glacier G40 ASUS GPU Block brings the ultimate cooling performance with unique water block features to build stunning water-cooled systems.
Phanteks Glacier G40 ASUS Strix/TUF RTX 4090/4080
Phanteks’ Glacier G40 ASUS GPU Block provides a high-performance water-cooling solution custom-designed for the latest ASUS GeForce RTX 4000 series cards. A transparent acrylic jet plate is positioned directly over the GPU die to ensure optimal heat transfer. The backplate is included with all models to provide a smooth integrated look while providing additional cooling to the back of the PCB. In addition, the fullcover copper cold plate directly cools all memory and power delivery components on the PCB with high-quality thermal pads. The Glacier G40 ASUS GPU Block also introduces some new features, such as a new fitting location to allow for better tube routing, even in the most compact chassis. To improve stability, a GPU support bracket is added to connect the water block to the rear PCI bracket so that the GPU is mounted more securely.
Like all Phanteks’ Glacier products, the Glacier G40 ASUS GPU Block is made in Taiwan using only 100% copper, cast acrylic, anodized aluminum covers, and extremely durable Viton O-rings known from the automotive and aerospace industries. The integrated D-RGB lighting beautifully complements the water block and can synchronize with Phanteks’ D-RGB accessories and compatible motherboards. The Glacier G40 ASUS GPU block will be available in Satin Black, Chrome and Matte White color finishes.
Pricing and Availability: – Available now
GLACIER G40 ASUS GPU Block:
SATIN BLACK €249.90 / £229.90 / $249.99
CHROME €269.90 / £244.90 / $269.99
MATTE WHITE €269.90 / £244.90 / $269.99
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
In a surprise turn of events on Friday, ASUS revealed the ROG X570 Crosshair VIII Extreme E-ATX motherboard. For Asus, this marks a return to the Extreme designator for AMD boards and is the latest flagship supplanting the Formula series. The ROG X570 Crosshair VIII Extreme supports all modern Ryzen CPUs (2000 series and newer) and APUs (2000 G Series and newer) and features an 18+2 phase VRM design with 90A power stages, microfine alloy chokes, and 10K Japanese-made black metallic capacitors. Pricing and availability have not been released at this time, but we’ll keep you posted. Below are additional specifications taken from the ASUS website.
Alphacool announced the launch of two M.2 SSD water blocks, the HDX Apex aRGB Acryl and HDX Apex Acetal. As you would expect, the HDX Apex aRGB Acryl features a clear acrylic top with addressable RGB lighting, while the acetal version is black POM. Both blocks are nickel-plated copper with G1/4″ ports and transfer heat from the SSD controller through a 3 W/mK thermal pad. The price is $31 for either option. Below is Alphacool’s press release and links if you wish to purchase.
It has come to our attention that NVIDIA is making sure that there will be no voltage control for their GK100 line up. The news comes via a forum post at the EVGA forums (which we confirmed independently) and it’s not pretty as far as overclockers are concerned.
Phanteks has just announced its Glacier G40 ASUS Strix/TUF water block for the new RTX 4090 and 4080 GPUs. The full-cover copper cold plate is designed to cool the entire GPU including the memory and power delivery components. The addressable RGB lighting looks fantastic through the clear acrylic top. The location of the fittings has also been revamped to assist hose routing as the 4000 series GPUs are incredibly large. The new blocks are available in satin black for $249.99 or your choice of chrome or matte white for $269.99 on the Phanteks website. Below is Phanteks' press release.
We use cookies to ensure that we give you the best experience on our website. If you continue to use this site we will assume that you are happy with it.OkPrivacy policy
No replies yet
Loading new replies...
