Table of Contents
Today, Phanteks announced its all-new T30 120 mm fan alongside an update to the already popular Glacier One series AIO CPU coolers. The new T30 120 mm fan ($29.99) features a mode switch that allows the user to select between three different fan configurations including Advanced Mode, Performance Mode, and Hybrid Mode. The Advanced Mode option is for extreme performance and allows the fan to spin up to 3000 RPM. The Performance Mode setting is used to accomplish a balance between performance and noise with a maximum fan speed of 2000 RPM. Finally, the Hybrid mode furthers noise reduction by allowing the fan to remain at 0 RPM until the PWM signal reaches 50%. The top speed for Hybrid Mode is set to 1200 RPM.
The Glacier One 240 T30 AIO CPU Cooler ($169.99) adds a pair of T30 120 mm fans to the already famous Glacier One AIO cooler. Below are some highlights from the Phanteks press release and product information sheets.
Phanteks T30 120 mm Fan and Glacier One 240 T30 AIO CPU Cooler
A NEW STANDARD IN PC COOLING – Phanteks launches the new T30-120 ultimate fan alongside the new Glacier One 240 T30 AIO liquid CPU cooler
T30 120mm Fan
Rotterdam, The Netherlands – August 12th, 2021 – After years of development and rigorous testing, Phanteks today releases the ultimate T30-120 cooling fan alongside the new premium Glacier One 240T30 All-in-One Liquid CPU cooler. Developed in collaboration with SUNON, the Phanteks T30-120 fan brings unparalleled performance to PC cooling for any scenario. The new T30-120 fan incorporates the latest innovation in engineering with the premium LCP (Liquid Crystal Polymer) material to achieve unprecedented cooling performance and acoustics. With its builtin fan profiles and a wide RPM range, the T30-120 can be tuned for silent, balanced, or extreme performance operation via a simple switch. The new Glacier One 240T30 includes the new T30-120 fans and thicker 38mm radiator to deliver 360-sized performance in a 240mm form factor. The pump unit features the highly reliable Gen7 pump from Asetek with PWM control and an infinity mirror pump cap with tempered glass and aluminum panels.
T30 120mm Fan
T30 120mm Fan
T30-120 Ultimate Fan
Glass Fiber Reinforced LCP (Liquid Crystal Polymer) Material
Constructed from the absolute best glass fiber reinforced LCP (Liquid Crystal Polymer), the fan blades and frame are immensely rigid and durable. The T30-120 fan is build to last using the very best glass fiber reinforced LCP material for both frame and blades, instead of the regular PBT material that is used for most fans.
Optimal Aerodynamics
Thanks to the excellent material properties of LCP (Liquid Crystal Polymer) and high precision manufacturing, the T30 is designed with exceptional aerodynamic features. The T30’s fan blade tip has a continuous and small 0.5mm clearance (distance of the blade tip to the inner frame) to reduce turbulence and deliver unparalleled noise-normalized performance.
Increased Fan Thickness to 30mm with 25% Larger Fan Blades
The Phanteks T30-120 features a unique 30mm fan frame that results in a 25% larger fan blade. By increasing the total height of the T30-120 fan from the standard 25mm to 30mm the actual fan blades are 25% higher. This results in significantly higher airflow performance and a better airflow vs noise ratio.
T30 120mm Fan
T30 120mm Fan
T30 120mm Fan
T30 120mm Fan
Glacier One 240T30 All-in-One Liquid CPU Cooler
The new Glacier One 240T30 is equipped with two T30-120 fans and a new 38mm thick 240mm radiator to bring performance to a whole new level. Installation is a breeze thanks to the pre-filled all in one solution, flexible braided tubing and Tube Clips that helps routing the tubing and fan cables.
The Glacier One 240T30 brings 360-sized performance in a 240mm form factor with its premium build quality and components:
• High-performance water cooling for Sockets LGA 115x, 1366, 2011, 2011-3, 2066, 1200 and AM4, sTRX4*, TR4*
(*Threadripper bracket included with CPU).
• Support for the upcoming Intel LGA 1700 socket through Phanteks’ customer service.
• D-RGB lighting is controlled and synchronized with Phanteks’ D-RGB lighting products and/or D-RGB equipped cases and motherboards.
Keep your system cool with the Phanteks T30-120 ultimate fan and the Glacier One 240 T30.
Availability August 2021
T30-120 FAN SINGLE PACK: €29,90 / £25.99 / $29.99
T30-120 FAN TRIPLE PACK: €84,90 / £74.99 / $84.99
GLACIER ONE 240 T30: €169,90 / £149.99 / $169.99
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Intel is bringing out its Intel i7 Broadwell-E. What coolers and heatsinks should you use for one of these beasts? The Intel i7 is a Broadwell-E on a 14nm process, with a TDP of 140 watts. The chip will arrive with options for 10, 8 or 6 cores. Joe Shields (earthdog) has done a review of one of the Broadwell-E chips and associated motherboard. This summary will review some of the coolers you should consider for your new chip.
This morning, Phanteks announced two new cases, the Eclipse P600S and Evolv X Matte White Edition. Each chassis allows for dual system capabilities in a mid-tower platform. TheEclipse P600S is fitted with soundproofing panels while the Evolv X Matte White is an all-white version of the current Evolv X. Additionally, Phanteks announced white versions of its SK PWM fans, VerticalGPU Bracket designed for the P300A, P360A, and P400A chassis, and three Gen4 riser cables. All products are expected to be available this month. Please continue reading Phantek’s press release for additional details and pricing.
Early this morning, Phanteks announced an all-white 1000 Watt version to its AMP power supply line-up. As with all of the AMP series power supplies, the all-white 1000W features an 80 PLUS Gold efficiency rating and utilizes a “Hybrid Silent Fan Control” to reduce noise while controlling the required cooling. Additionally, the AMP series is compatible with Phanteks other PSU series, the Revolt Pro. This allows for either an increased power output or power redundancy. Phanteks has set the White AMP 1000W power supply price at $159.99 and should be available this month. Below is Phanteks’ press release.
These look to be very good, for sure. I wouldn't hesitate to use them but they wouldn't fit in my current build.Tom's mentions that they aren't all that "pretty" but that can be resolved through 3D printing some covers/caps/fandannas
These are definitely on my short list for my next build.
Time to hack some PSU peripheral modular connectors to Deans T-connnectors to power them! :D
That, or use multiple Fan hubs if you aren't comfortable hacking cables.
I put a SATA-powered 10 port fan hub in my last build and then added a 2nd 8-port Molex-powered hub just so I could split the load of 10 fans among two fan hubs. (Technically, only 9 fans on the hubs since the rear exhaust fan is connected to the mobo pwm connector)
Using two fan hubs also helped out with the cable management on the backside of the mobo tray in the case since I didn't have to route all the fan cables into one large "charlie foxtrot" of cables.
We use cookies to ensure that we give you the best experience on our website. If you continue to use this site we will assume that you are happy with it.OkPrivacy policy
Loading new replies...
1
1
1
1
1
1
1
1
1
