Phanteks Introduces All-White AMP 1000W Power Supply
Phanteks
Phanteks
Early this morning, Phanteks announced an all-white 1000 Watt version to its AMP power supply line-up. As with all of the AMP series power supplies, the all-white 1000W features an 80 PLUS Gold efficiency rating and utilizes a “Hybrid Silent Fan Control” to reduce noise while controlling the required cooling. Additionally, the AMP series is compatible with Phanteks other PSU series, the Revolt Pro. This allows for either an increased power output or power redundancy. Phanteks has set the White AMP 1000W power supply price at $159.99 and should be available this month. Below is Phanteks’ press release.
PHANTEKS ANNOUNCES ALL-WHITE AMP 1000W POWER SUPPLY
Rotterdam, The Netherlands – May 13th, 2022 – Phanteks welcomes the all-white 1000W power supply to the AMP Series, an ultra-high efficiency, 80 PLUS Gold Certified power supply that is perfectly capable of driving high-end systems with new-gen power-hungry GPUs. The power supply provides high efficient 1000 wattages in a 140mm housing for a compact design and comes with modular, white, flat power cables to make installation easy and clean. The AMP series features a Hybrid Silent Fan Control that achieves optimal cooling with temperature-controlled fan speed and fan-less mode for silent performance. The AMP series is also Revolt Pro-Link certified to provide 100% compatibility, reliability, and stability to work directly with the Revolt Pro expandable PSU allowing you to increase your power output.
Power your system with the new AMP series power supplies and stay worry-free with the 10-year warranty.
Pricing and Availability: – May 2022
AMP 1000W 80 PLUS GOLD White Edition: May 2022 €159.90 / $159.99
-John Nester (Blaylock)
About John Nester 399 Articles
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Loading new replies...
Avatar of Overclockers.com
3,220 messages 214 likes
Early this morning, Phanteks announced an all-white 1000 Watt version to its AMP power supply line-up. As with all of the AMP series power supplies, the all-white 1000W features an 80 PLUS Gold efficiency rating and utilizes a "Hybrid Silent Fan Control" to reduce noise while controlling the required cooling. Additionally, the AMP series is compatible with Phanteks other PSU series, the Revolt Pro. This allows for either an increased power output or power redundancy. Phanteks has set the White AMP 1000W power supply price at $159.99 and should be available this month. Below is Phanteks' press release.
Click here to read more!
Reply Like
