Table of Contents
This morning, Phanteks announced two new cases, the Eclipse P600S and Evolv X Matte White Edition. Each chassis allows for dual system capabilities in a mid-tower platform. TheEclipse P600S is fitted with soundproofing panels while the Evolv X Matte White is an all-white version of the current Evolv X. Additionally, Phanteks announced white versions of its SK PWM fans, VerticalGPU Bracket designed for the P300A, P360A, and P400A chassis, and three Gen4 riser cables. All products are expected to be available this month. Please continue reading Phantek’s press release for additional details and pricing.
PHANTEKS LAUNCHES ECLIPSE P600S & EVOLV X MATTE WHITE EDITIONS ALONG WITH GEN4 PCI-E RISER CABLES
Rotterdam, The Netherlands – January 26th, 2022 – Phanteks announced the launch of the new Eclipse P600s and Evolv X Matte White Edition along with the Gen4 PCI-e Riser Cables. Its stunning all-new matte white look makes the Evolv X and Eclipse P600s a perfect combination for color-themed builds while maintaining a wide range of flexibility and premium materials.
Evolv X & Eclipse P600S Matte White Edition
The Evolv X and Eclipse P600s are mid-tower cases that offer dual system capabilities, massive storage, and extensive water-cooling support. The Evolv X features a 3mm aluminum exterior with hinged clear tempered glass, improved airflow, smart spacing, and additional mesh elements. The P600s, a hybrid forged between silent and high-performance chassis. Designed with an effective soundproofing panel and Phanteks’ new high-airflow fabric, the Eclipse P600s offers the full potential of two opposites, minimum noise, and maximum airflow. Whether it’s a high-end water-cooling build, professional data storage system, or even a dual-system PC, both cases can accommodate your desired configuration thanks to the effective interior design that utilizes the space efficiently.
SK PWM D-RGB White Fans
The SK fans are known from the award-winning Eclipse Series chassis such as the P400A and its cooling performance. The built-in PWM capabilities help precisely control the speed to offer higher airflow or a quiet cooling solution when needed. The new white SK D-RGB models further complement the new white chassis available from Phanteks.
Complete range of Gen4 PCIe Riser Cables and Vertical GPU Bracket
The new Gen4 Vertical GPU Bracket allows vertical placement of any graphics card with full Gen4 speeds. Designed specifically for the P300A/P360A/P400A chassis that have an open PCI slot to allow the Vertical GPU Bracket to be installed directly. Any other ATX chassis can be easily modded to support the Gen4 Vertical GPU Bracket. Graphic Cards with up to 4-slot sizes are supported with access to ports on the first 2 slots. The included 220mm long PCIe Gen4 x16 Riser Cable allows any Gen4 graphics card to run at full speed without compromise. Also, Phanteks will offer the Flat Line PCIe Gen4 x16 Riser Cables. The dual-layer design improves the performance and stability of the high bandwidth signals ensuring the system are running stable and reliable. Each individual laneway is shielded from EMI/EFI interference to prevent interference between channels to further improve signal integrity. The Flat Line riser cables will be available in 150mm (90-degree adapter), 220mm (90-degree adapter), and 300mm (180-degree adapter)
Pricing and Availability: – January 2022
Evolv X Matte White: January 2022 €229.99 / £209.90 / $229.99
Eclipse P600S Matte White: January 2022 €179.99 / £159.90 / $199.99SK PWM D-RGB White:
SK PWM D-RGB White 120mm 3-Pack: January 2022 €34.90 / £30.90 / $34.99
SK PWM D-RGB White 140mm 3-Pack: January 2022 €39.90 / £38.90 / $44.99Vertical GPU Bracket Gen4: January 2022 €69.90 / £60.90 / $69.99
Gen4 Riser Cables:
PH-CBRS4.0_FL15: January 2022 €59.90 / £52.90 / $59.99
PH-CBRS4.0_FL22: January 2022 €59.90 / £52.90 / $59.99
PH-CBRS4.0_FL30 : January 2022 €59.90 / £52.90 / $59.99
No replies yet
Loading new replies...
