Scythe Mugen 5 ARGB Plus Heatsink Review
Scythe has brought to market another revision of its acclaimed Mugen 5 heatsink, the Mugen 5 ARGB Plus. In this update, the changes are mostly cosmetic now sporting an ARGB top cover and two ARGB Kaze Flex fans. However, this revision includes two fans with a higher maximum speed than the single fan used on the previous revision. We’ll check out the new RGB implementation, and see if the dual fan solution improved performance.
Specifications & Features
(Courtesy of Scythe)
Scythe Mugen 5 ARGB Plus Specifications
Model # SCMG-5102AR
Dimensions 136 x 136 x 157.5 mm (including fan)
Weight 1060 g (including fan)
Socket Compatibility Intel: LGA 775/115x/1366/2011-v3/2066
AMD: FM1/FM2(+)/AM2(+)/AM3(+)/AM4
Baseplate/Heatpipe Material Nickel-plated copper
Fin Material Aluminum
Heatpipes 6 x 6 mm
Kaze Flex 120 ARGB PWM Fan Specifications
Model # KF1225FD15AR-P
Fan Dimensions 120 x 120 x 27 mm
Fan Speed 300 ± 200 ~ 1500 ± 10% RPM
Noise Level 4.0 ~ 29.75 dBA
Air Flow 16.6-66.47 CFM
Static Pressure 0.0762 ~ 1.67 mmH2O / 0.75 ~ 16.38 Pa
Input Power 2.4 W
Voltage 12 V
Amperage 0.20 A
Features
Asymmetric Design
Thanks to an offset layout, the cooler will not overhang RAM slots. On 2011(v3) / 2066 platforms, the rear fan can be mounted higher to fit tall memory heat-spreaders, which increases the overall height of the cooler.
Fully Addressable RGB Sync
Equipped with dual ARGB Kaze Flex PWM fans with max. speed of 1500 rpm and an ARGB top cover, the cooler provides top-tier performance as well as vivid, colorful effects from all view angles.
Wired ARGB Controller
The cooler is sync and controlled with ARGB motherboard or ACT-1000ARL included. The case reset button can be connected to the controller making it easier to choose lighting mode. The controller is programmed with 14 modes of lighting effects and 5 modes of lighting speed, 16 million colors can be achieved easily with this small controller.
Packaging & Accessories
Scythe’s packaging is always loaded with information to ensure sure potential buyers have everything they need to know about the heatsink before they buy. On that front, there is an excellent isometric picture of the Mugen 5 ARGB with two Kaze Flex ARGB fans installed. Of course, Scythe’s logo is in the top right, compatibility is listed in the bottom left, and ARGB support is in the bottom right. On one side, we have detailed specifications and dimensions for the heatsink, fans, and ARGB connectors. The other side highlights three features, including the ARGB control box, ARGB equipped Kaze Flex fans and top cover, and a good view of the asymmetrical design for the Mugen 5 ARGB.
Box Front
Box Back
Box Side
Box Side
When opening the box and unpacking the Mugen 5 ARGB, we first remove a flat box that includes most of the accessories. Then, we have one of the Kaze Flex ARGB fans and a small cardboard-wrapped bag with the ARGB control box with its cables. Next, is the other Kaze Flex ARGB fan.
Unpacking
Unpacking
Unpacking
Unpacking
Finally, we have the foam-wrapped Mugen 5 ARGB. Overall, the packaging seems really well thought out with plenty of protection for the heatsink, fans, and accessories.
Unpacking
Unpacking
Unpacking
Accessories
The accessories include an installation manual for the Mugen 5 ARGB, user guide for the ARGB control box, hardware bag, Y-splitter for the fans, a long screwdriver, and the ARGB control box. As with the Mugen 5, it’s good to see a screwdriver is included since it’s almost required to install the heatsink (a small wrench might work, but I haven’t tried). The bag has a tube of thermal paste, backplate, Intel/AMD brackets, press-fit spacers, screws, and two sets of fan clips for the two Kaze Flex ARGB fans.
Accessories
Kaze Flex 120 ARGB PWM Fans
The fans included with the Mugen 5 ARGB are PWM versions of the Kaze Flex 120. These fans run up to 1,500 RPM and consume 2.4 W of power (the previous Kaze Flex ran at 1,200 RPM). As far as looks go, it has a black frame with translucent blades for the RGB lighting and a Scythe logo on the hub.
Kaze Flex 120 ARGB Fans
Model and Specs
The corners on the fans are rubber which minimizes or even eliminates any vibrations that could occur while the fans are running. When looking inside of the fan hub, we can see the RGB LEDs are lined around the hub to project light onto the fan blades.
Rubber Corners
RGB LEDs
This last picture just shows the fan’s connectors, which include the PWM connector for power/speed control and the RGB headers to link the fans together and connect them to the control box.
Connectors
The Mugen 5 ARGB is made from aluminum and nickel-plated copper which gives it a uniform metallic finish. There are six heat pipes forming a u-shape through the base with the ends capped off with the ARGB top cover which completely hides the ends. Just like the non-ARGB Mugen 5, the fin stack has 39 fins with a density of around 10 fins per inch, so there’s plenty of room for airflow across the heatsink. We can also make out some of the asymmetrical design and notched edge, but we’ll get a better side shot and bottom shot in a bit.
Bare Mugen 5 ARGB
Bare Mugen 5 ARGB
Bare Mugen 5 ARGB
Bare Mugen 5 ARGB
With a bottom view of the Mugen 5 ARGB, the asymmetrical design can be seen in more detail. The heat pipes bend towards one side placing the fin stack off-center of the base. This, along with the notched bottom edge, allows for better memory compatibility and easier access to the DIMMs.
Mugen 5 ARGB Bottom
Mugen 5 ARGB Notch
Again, just like the Mugen 5, the base of the ARGB version isn’t quite a mirror finish, but still really smooth.
Mugen 5 ARGB Base
ARGB Gallery
Here are a few pictures of the Mugen 5 ARGB and Kaze Flex ARGB fans with the lighting mode in its default “Rainbow” mode. In this mode, the colors are constantly changing and flowing around the hub and top cover.
ARGB
ARGB
ARGB
ARGB
Controlling the ARGB
Scythe’s ARGB control box looks similar to all the other control boxes out there from other manufacturers, but there are two unique features to Scythe’s implementation. The first is the two magnets on the bottom which allows you to attach the control box to any steel parts of your case (magnets won’t work on aluminum since it’s non-ferrous).
The second feature is rather ingenious, and it allows the control box to be connected to your case’s reset switch which allows you to use the reset switch to control the colors of the Mugen 5 ARGB and its fans. Personally, I cannot remember the last time I actually needed to use the reset switch on a case, so this feature gives a new purpose to that often forgotten switch.
ARGB Control Box
ARGB Control Box
ARGB Control Box
ARGB Control Box
ARGB Control Box Usage
There is a single LED on the control box which can be either Green (default), Red, or Blue. Each color represents a different adjustment mode for the control box. Green is Mode Selection, Red is Speed Adjustment, and Blue is Brightness Adjustment. To change to a different adjustment mode, the button on the control box has to be pressed and held for three seconds.
  • When the indicator light is green, press the button to switch the lighting mode (14 modes in total). The default is Rainbow mode.
  • When the indicator light is Red, press the button to adjust the frequency speed of the current lighting mode (5 speeds).
  • When the indicator light is Blue, press the button to adjust the brightness for the current lighting mode (5 brightness levels).
  • In any mode, long-pressing the button for five seconds will restore the default settings – indicator light will be Green, lighting mode will be Rainbow, and speed/brightness will return to their default setting.
Installation
Now, we’ll go through a mock installation to show all the steps involved when mounting the Mugen 5 ARGB. The first step is to mount the backplate onto the motherboard with four thumbscrews. You’ll need access to both sides of the motherboard simultaneously to hold the backplate in place while securing the thumbscrews. They can then be tightened down with the included screwdriver.
Backplate
Backplate with Mounting Screws
Once the backplate has been installed, the cross braces are secured with four screws and the included screwdriver.
Mounting Braces Installed
The next step is to apply thermal paste to the CPU, and Scythe kindly includes a tube of paste for those who may not have any. I personally use the “dot” method of applying thermal paste by using a blob of paste the size of a small pea or so in the center of the CPU and let the pressure of the heatsink spread the paste across the CPU. Once the paste is applied, we can mount the Mugen 5 ARGB by using the screwdriver and alternating between screws every few turns to apply pressure as evenly as possible until the heatsink is securely mounted.
Crossbar Screw
Crossbar Screw
Test Setup & Methodology
Test Setup
CPU Intel i7 8700K @ 4.7 GHz, 1.125+ V
Motherboard ASUS ROG Strix Z370-F Gaming
RAM 2 x 8 GB G.Skill TridentZ DDR4-3200 15-15-15-35
GPU EVGA RTX 2060 XC ULTRA
Storage Intel SSD 660p Series 1 TB M.2 NVMe
PSU Seasonic X-750 Gold
Heatsinks Liquid Coolers
Air Coolers
Equipment
Fluke 52 II Dual Input Thermometer
Tenma Sound Level Meter
Methodology
All testing was performed on an open test bench, which minimizes ambient temperature and gives a “worst case” scenario for sound level.
Cooling performance was tested as follows:
  • Disabled all BIOS settings that cause the CPU clock speed and/or Vcore to fluctuate (although there was still some Vcore fluctuation under load).
  • Ambient temperature was measured with a Fluke 52 II at ~1 inch from the intake fan(s). Then, subtracted from the recorded temperatures to get ΔT.
  • Varied Vcore (in BIOS) from 1.125 V to 1.375 V in 0.050 V increments to increase heat. Stopped increasing Vcore once a core reached ~100 °C.
  • 20-pass 2048 MB RAM LinX runs at each Vcore interval were used to load the CPU.
  • CoreTemp was used to record minimum and maximum core temperatures.
Sound level in dBA was measured 10 cm from the intake fan with the fan speed set to 100%. Then, the sound level was estimated for other distances using the following formula:
L2 = L1 – 20 * log10(r2/r1)
  • L2 = dBA @ desired distance
  • L1 = dBA @ reference distance
  • r1 = reference distance
  • r2 = desired distance
Why estimate sound level instead of measuring at further distances? It’s because the meter I’m using is most accurate between 40-130 dBA, so I needed to measure really close to the source to make sure my readings were within that range to get the most accurate measurements.
qwerty
Results
Cooling Performance
Performance of the Mugen 5 ARGB is as expected, in the range with the other heatsinks. Looking at the middle-of-the-road Vcore (1.225 V), all of the single-tower heatsinks have virtually identical performance. Then, as the voltage is increased, the Mugen 5 ARGB separates from the rest of the heatsinks leaving it and the Venomous X as the best single-tower heatsinks. Of course, the dual-tower coolers, FUMA and NH-D14, have some separation in the form of allowing more heat before the CPU throttles. The liquid coolers easily outperform the heatsinks as seen by even more separation.
Sound Level
The Mugen 5 ARGB has an average performance in noise level, which contrasts the low noise level of the standard Mugen 5 Rev. B. The reason behind this discrepancy is definitely the two Kaze Flex ARGB fans. The Mugen 5 ARGB uses two fans instead of one, and the max speed of those fans is higher than the Mugen 5 Rev. B fan.
Conclusion
Scythe’s Mugen 5 ARGB is a great looking cooler with a bare metal aesthetic combined with ARGB on the top cover and fans. This means the cooler can be adjusted to match your build’s theme throughout its life and component changes.
Some features of the Mugen 5 ARGB that I can appreciate are (1) the long screwdriver for installation so the customer doesn’t have to worry about that after purchase, (2) the ARGB control box can be connected to the reset switch for lighting adjustment without having to open up the case, and (3) the ARGB top cover makes it easier to appreciate the lighting modes through a side window.
The included Kaze Flex ARGB fans run at a higher RPM (1,500) than the standard Kaze Flex (1,200) fan used with the Mugen 5 non-ARGB. The higher speed combined with a push-pull fan configuration resulted in a noticeable noise increase, but also a noticeable temp drop during higher heat loads. These fans also kept the rubber corners to help prevent any additional noise that could be caused by vibrations.
Performance-wise, the Mugen 5 ARGB falls closely in line with its brother, the Mugen 5 Rev. B, which was to be expected since the only change that would affect performance is using two higher-speed fans. The effect of that change can be seen in the graph where the plots for the Mugen 5 and Mugen 5 ARGB start and continue to diverge as the heat load is increased. At one point there is a 5C difference between the two, though the average is smaller.
The Mugen 5 ARGB has an MSRP of $79.99, which is $30 more than the standard Mugen 5 Rev. B. That $30 extra goes toward supplying two upgraded fans (higher speed and ARGB), adding an ARGB top cover, and including an innovative ARGB control box. For the price, there are three better air coolers in my testbed: the Noctua NH-D14 ($80), Scythe’s FUMA Rev. B ($42), and Thermalright’s Venomous X (discontinued) all perform either same or better for equal or less money. So, what you get is a $30 premium for ARGB and a performance boost over the original Mugen 5 Rev. B.
Click to find out what this means
– Matt T. Green (MattNo5ss)
Related Reading
About Matthew Green 57 Articles
Self-Proclaimed WordPress Editing Guru
Discussion
Leave a Reply
Your email address will not be published.
