Thermalright Introduces Frost Commander 140 CPU Cooler
Thermalright has just announced the Frost Commander 140 CPU air cooler. This dual tower cooler features a total of five 8 mm heat pipes and a nickel-plated copper base for superior heat transfer. The two included fans are a TL-C12 Pro G 120 mm front fan and a TL-D14X 140 mm center fan. Both utilize Thermalright’s S-FDB (Fluid Dynamic) bearings and 4-pin PWM connectors. Overall dimensions are 140 mm long, 121 mm wide, and 160 mm tall. This places it in the average size for dual-tower coolers currently on the market. Pricing is not yet available.
Thermalright Frost Commander 140 Dual Tower CPU Cooler
Heatsink Specifications
Dimension:L140 mm x W121 mm x H160 mm
Weight:1000g
Heat pipes:8mm heatpipe x 5 units
Fin:T = 0.4 mm;Gap=1.8 mm
Fin pcs:53 pcs
Copper Base:C1100 Pure copper nickel plated
TL-C12 Pro G FAN Spec
Dimension:L120 mm x W120 mm x H25 mm
Weight:165g
Rated Speed:1850 RPM±10% (MAX)
Noise Level:29.6 dBA
Air Flow:82 CFM (MAX)
Air Pressure:2.1mm H2O (MAX)
Ampere:0.25 A
Connector:4 Pin (PWM Fan connector)
Bearing Type: S-FDB Bearing
TL-D14X FAN Spec
Dimension:L140 mm x W152 mm x H27 mm
Weight:175g
Rated Speed:1800 RPM±10% (MAX)
Noise Level:30.2 dBA
Air Flow:95.5 CFM (MAX)
Air Pressure:2.25mm H2O (MAX)
Ampere:0.30 A
-John Nester (Blaylock)
Recent Articles
About John Nester 399 Articles
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Loading new replies...
Avatar of EarthDog
EarthDog
Gulper Nozzle Co-Owner
77,784 messages 4,456 likes
This thing looks yuge! Wonder if it cools well....
Reply Like
Avatar of Blaylock
Blaylock
8,080 messages 1,041 likes
It's just a little smaller than the NH-D15. I'm curious about it's cooling too.
Reply Like
Avatar of Nebulous
Nebulous
Dreadnought Class Senior
12,630 messages 1,318 likes
Wow! Big sink indeed! I hope it cools as good as it looks. It might make me go back to air..........nahh, not really :rofl:
Looks really good tho!
Reply Like
Avatar of Mr.Scott
Mr.Scott
Beamed Me Up!
6,216 messages 278 likes
Pretty much all Thermalright products never fail to perform.
Reply Like
Avatar of Nebulous
Nebulous
There's a dual tower sink that came out with dual fans, but I can't for the life of me remember it. Really popular at the time and it came in Blue or White.
Reply Like
Avatar of BugFreak
BugFreak
2,463 messages 718 likes
Figures, I finally break down and buy a Noctua D15 because I couldn't find something comparable by Thermalright. Now they release this. Looks great for sure.
Reply Like
Avatar of freeagent
freeagent
6,358 messages 865 likes
Really? They have a few..
Lol I bought this cooler the day it was released. Superfan? maybe.. but really I just wanted something new, something not so gargantuan, something that wasnt Noctua :D
I will be sure to post back my results :thup:
And I figured if the cooler wasn't comparable to what I already have I sure could use those fans, they are more than half the price of the cooler on their own with shipping lol..
Reply Like
Avatar of Blaylock
Blaylock
If you could, post some results compared to your Noctua please.
Reply Like
Avatar of freeagent
freeagent
I would love to, but I sold my D14 years ago. But I do have the same hardware I used to run with it, that is where I am drawing my conclusions.
Reply Like
Avatar of BugFreak
BugFreak
Yea the only one I could find was the Macho which didn't fit what I wanted. It might have just been a timing thing but I couldn't find one that compared to the D15.
Reply Like
