Thermaltake has recently released the SWAFAN 12/14 RGB Series fans. With an innovative swappable fan blade, the SWAFAN can reverse the airflow direction. This allows the added benefit of keeping the RGB lighting facing the direction you choose. Our friends at Techpowerup have recently reviewed the new SWAFAN, and though they did not perform as well as hoped on radiators, they should serve well as case cooling fans. They are available in 120 mm or 140 mm and are sold in packs of three for $119.99 and $129.99, respectively. If the sticker price hasn’t scared you away, continue reading Thermaltake’s press release below for complete details.
Thermaltake SWAFAN 12/ 14 RGB
First Swappable Fan Blade Design by Thermaltake
Now Available for Purchase
Thermaltake SWAFAN 12/14 RGB
Thermaltake, the leading PC DIY premium brand for Case, Cooling, Gaming peripherals, and enthusiast memory solutions, is delighted to announce the first-ever swappable fan blade design here at Thermaltake, SWAFAN 12/14 RGB Radiator Fan is available for purchase now. One of the most prominent highlights of SWAFANs is that it has two types of fan blades that are swappable, not only enabling users to orient the airflow direction depending on however they like it but, meanwhile, providing glorious full RGB lighting of the fan. From tech lovers, pc builders, pc enthusiasts to modders, we can all appreciate how functionally capable this design is and take full advantage of its convenience. Let’s take a look at more details on SWAFAN 12/ 14 RGB below.
SWAFAN 12/ 14 RGB Radiator Fan’s name originates from “swap fan;” It features a swappable fan blade design, which provides more flexibility while building a PC since users can adjust the airflow direction by simply swapping out the fan blades enclosed in the package. As we continue to push boundaries and redefine the perfect user experience, we came up with this incredibly brilliant design, enabling users to build, test, and adjust the airflow orientation simultaneously and achieve the most optimal in-case airflow without unscrewing the installed fans every single time. Other than that, it is effortless for users to clean the fan blades by merely popping them out. Thus, this can save users so much time so they can spend their valuable time on things that matter to them. On top of that, we enclose a bearing lubricant for you to take care of your fan after multiple swaps.
For cooling performance, SWAFAN 12/ 14 RGB is no slouch, it comes with a powerful PWM-controlled fan that features a unique 9-fan blade design, which was deliberately engineered to generate high air pressure while keeping a large amount of airflow for both fan blades. It also has an enhanced fan speed of up to 2000 RPM, ensuring its impeccable competency in terms of cooling performance. Spectacular RGB lighting effects are the icing on the cake to suffice your need for aesthetics, providing three addressable LED rings with 30 ultra-bright LEDs in total with a coverage of 16.8 million uniformity colors. SWAFAN 12/ 14 RGB also adopts the latest 4th generation software controller, which brings an uninterrupted connection between RGB Software and components. Plus, light effects can be easily tweaked to your satisfaction through NeonMaker software or TT RGB Plus 2.0 to choose stunning RGB lighting effects that suit you.
To summarize, with incredible swappable fan blade design, easily customizable lighting effects, and amazing cooling performance, SWAFAN 12/ 14 RGB is ideal for any system you plan to build and it is in stock for purchase now.
Features of Thermaltake SWAFAN 12/ 14: Brand-new Swappable Fan Blade Design
SWAFAN RGB Series Radiator Fan includes 6 detachable fan blades, 3 black labeled standard fan blades pre-installed on the fan frames, and 3 silver labeled reverse fan blades, providing more flexibility while installing the PC, meaning you can swap the fan blades to achieve your ideal airflow direction. No matter where you install SWAFAN, its glorious RGB lighting effects will always shine through. Performance, cooling, and perky RGB lighting, you can have it all. Great Cooling Performance
This powerful PWM-controlled fan features a unique 9-fan blade design and has an enhanced fan speed of up to 2000 RPM, ensuring outstanding cooling performance.
Black labeled Standard Fan Blade can be used for air intake —
Max Air Pressure: 2.58 mm H2O
Max Air Flow: 53.02 CFM
Silver labeled Reverse Fan Blade can be switched out for air exhaust —
Max Air Pressure: 2.19 mm-H2O
Max Air Flow: 54.85 CFM
Spectacular Lighting Effects
SWAFAN highlights 3 addressable LED rings with 30 ultra-bright LEDs in total (Front: 12 / Middle: 6 / Back: 12) and the coverage of 16.8 million uniformity colors.
You can easily tweak your lighting effects through TT RGB Plus 2.0 and NeonMaker software to create stunning lighting effects.
4th Gen Controller Adopted
With the latest 4th generation software controller adopted, SWAFAN offers a stable and smooth connection while syncing up TT RGB Plus supported products
*You can add up to 3 SWAFANs to this controller and a total of six SWAFANs with 2 controllers by a molex cable.
Built with Detachable Hydraulic Bearings
Featuring a specifically engineered detachable Hydraulic Bearing design, SWAFAN has gone through hours of rigid testing, ensuring it stays in the perfect condition even after swapping fan blades several times.
*The package includes bearing lubricant.
Anti-vibration Mounting System
The anti-vibration rubber pads provide better overall vibration absorption, allowing the fan to spin at a higher level with stability.
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Thermaltake rarely sits still and constantly strives to bring new and innovative products to market. Today’s review of the Armor Revo Gene is yet another example of an existing series being re-worked. The Gene version of the Armor Revo is a bit smaller than the original and includes a few enhancements. So, how did Thermaltake do this time around? Let’s find out, shall we?
With small form factor components becoming increasingly popular for desktop and gaming applications, the demand for cases to house these components is on the rise. It seems almost all case manufacturers now offer Micro-ATX or Mini-ITX cases of one kind or another. Today, we’ll have a look at one of Thermaltake’s newest offerings in this category – the A30i Speed Edition Gaming Cube. With support for Micro-ATX and Mini-ITX motherboards, full size power supplies, and long video cards, it certainly appears to have the features most enthusiasts would look for in a small form factor case. Let’s have a look for ourselves and find out if the A30i Speed Edition Gaming Cube has what it takes to warrant your consideration.
Thermaltake announced today the official release of the TOUGHRAM RGB and TOUGHRAM XG RGB memory kits. The XG variant is the premium option and is available with speeds ranging from 3600 Mhz to 4600 Mhz with 16 GB (2x8GB) capacity while the TOUGHRAM RGB (Non-XG) features a painted aluminum heat spreader painted in either metallic gold or racing red. The RGB for the Non-XG is more subtle with only 10 LEDs and will only be available as a 3600 Mhz 16 GB (2×8 GB) kit. Pricing for the Non-XG kits starts at $155 (links below). Below is the Thermaltake press release.
Thermaltake has recently released the SWAFAN 12/14 RGB Series fans. With an innovative swappable fan blade, the SWAFAN can reverse the airflow direction. This allows the added benefit of keeping the RGB lighting facing the direction you choose. Our friends at Techpowerup have recently reviewed the new SWAFAN, and though they did not perform as well as hoped on radiators, they should serve well as case cooling fans. They are available in 120 mm or 140 mm and are sold in packs of three for $119.99 and $129.99, respectively. If the sticker price hasn't scared you away, continue reading Thermaltake's press release below for complete details.
We use cookies to ensure that we give you the best experience on our website. If you continue to use this site we will assume that you are happy with it.OkPrivacy policy
No replies yet
Loading new replies...
