Table of Contents
Thermaltake announced today the official release of the TOUGHRAM RGB and TOUGHRAM XG RGB memory kits. The XG variant is the premium option and is available with speeds ranging from 3600 MHz to 4600 MHz with 16 GB (2x8GB) capacity. They feature an aluminum heat spreader with 16 LEDs in eight controllable zones to illuminate an X-shaped light bar. Pricing starts at $170 and is available at TTPremium.com (see links below).
The TOUGHRAM RGB (Non-XG) features a painted aluminum heat spreader painted in either metallic gold or racing red. The RGB for the Non-XG is more subtle with only 10 LEDs and will only be available as a 3600 MHz 16 GB (2×8 GB) kit. Pricing for the Non-XG kits starts at $155 (links below). Here is the Thermaltake press release.
Thermaltake Releases High-End TOUGHRAM XG RGB Memory Kits with 16 LEDs and TOUGHRAM RGB in New Colors
For Gaming, Speed and Aesthetics
Taipei, Taiwan-Mar 15th, 2021-Thermaltake, the leading PC DIY premium brand for Cooling, Gaming Gear, and Enthusiast Memory solutions, today announced the official release of the TOUGHRAM XG RGB DDR4 16GB (8GB x 2) Memory Kit, and is now available for purchase on TTPremium.com and Thermaltake.com. The TOUGHRAM XG RGB comes in frequencies ranging from 3,600MHz up to 4,600MHz 16GB (8GBx2), featuring a distinguished style for users who seek unconventional gaming styled ram modules.
Compatible with the latest AMD and Intel® DDR4 motherboards, the TOUGHRAM XG RGB DDR4 16GB (8GB x 2) has been through rigorous tests in order to select tightly-screened ICs for high and stable performance. The aluminum heat spreader of the TOUGHRAM XG has been trimmed with a geometrical pattern for a sleek and fresh look, meanwhile it can also enhance heat dissipation while in use. As the high end memory kit of the TOUGHRAM series, the TOUGHRAM XG RGB has been upgraded to 16 LEDs with a unique X-shaped light bar to control 8 lighting zones for splendid colors. Users can choose over 25 pre-set lighting modes from the TOUGHRAM software, or to synchronize it with multiple RGB software including our advanced light editing software NeonMaker to set-up timeline. The TOUGHRAM XG continues the legacy of building a full RGB ecosystem, it can be synchronized to the TT RGB Plus software along with other enabled components. Other than that, the TOUGHRAM XG can support motherboards equipped with 5V addressable RGB header, allowing users to control lighting effects directly from the motherboard RGB software.
Today Thermaltake also launches its new TOUGHRAM RGB Metallic Gold and Racing Red DDR4 Memory Kit 3,600Mhz in 16GB kits (8GB x2). Themaltake aims to provide more alternatives for RGB enthusiasts to release their creativity on PCs, meanwhile enjoying reliable performance of both TOUGHRAM XG RGB and TOUGHRAM RGB Memory Kit.
Availability, Warranty, Compatibility, and Pricing
Thermaltake TOUGHRAM XG RGB DDR4 16GB (8GB x 2) and TOUGHRAM RGB Metallic Gold/Racing Red 3,600Mhz 16GB (8GBx2) Memory Kits are now available on ttpremium.com and are backed by a limited lifetime warranty for the RAMs, which is supported by the Thermaltake worldwide customer service and technical support network. For up-to-date pricing of the Thermaltake TOUGHRAM XG RGB 16GB (2x8GB) DDR4 Memory, please refer to thermaltake.com or contact your local Thermaltake sales or PR representative.Features of TOUGHRAM XG RGB series:
Sleek and Sophisticated Design
Designed with 2 different colors of aluminum and trimmed with a chrome stripe in the middle, the TOUGHRAM XG RGB provides a fresher look and is in its class of its own.
Geometric Styling with 16 LEDs
Comprised of 16 high-lumen addressable LEDs, the TOUGHRAM XG shines through with its unique X-shaped light bar that can control 8 lighting zones, delivering a more comprehensive and dynamic lighting experience.Tightly-Screened ICs
Memory chips are thoroughly-screened to provide optimal frequency and response time performance.2oz Copper PCB
Specially optimized 10-layer PCB with 2oz copper inner layer provides enhanced electrical conduction to deliver uncompromised speed and reliability for maximum overclocking performance.High Quality Gold Fingers
Use of 10μ gold fingers for enhanced durability and high wear resistance.Aluminum Heat Spreader
Use of aluminum heat spreader delivers exceptional heat dissipation to meet high-performance needs.
Exclusive TOUGHRAM Software
Monitor real-time temperature, frequency and performance via the simple interface with ease, and create stunning lighting effects with over 25 lighting modes, all included in the TOUGHRAM software. Users can also sync with TT RGB PLUS to maximize unique settings for their RGB color theme.Features of TOUGHRAM RGB Metallic Gold/Racing Red
Use of aluminum heat spreader which is coated with exquisite paint delivering exceptional heat dissipation to meet high-performance needs.
Illuminate and Impress
10 super-bright addressable LEDs deliver 16.8M full spectrum RGB color with dynamic lighting effects to bring your gaming system to life.Tightly-Screened ICs
Use of 10μ gold fingers for enhanced durability and high wear resistance.Extra Sturdy with a Fine Touch
Each RAM module weights up to 79.8g, with its heatsink accounting for 60.2g and a width spanning 1.8mm, this helps deliver outstanding heat dissipation and a solid touch.Exclusive TOUGHRAM Software
Monitor real-time temperature, frequency and performance via the simple interface with ease, and create stunning lighting effects with over 25 lighting modes, all included in the TOUGHRAM software. Users can also sync with TT RGB PLUS to maximize unique settings for their RGB color theme.For more details on TOUGHRAM XG RGB DDR4 Memory Kit 16GB (8GB x 2), please visit :
4600 MHz –
https://www.thermaltake.com/toughram-xg-rgb-memory-ddr4-4600mhz-16gb-8gb-x2.html
4400 MHz –
https://www.thermaltake.com/toughram-xg-rgb-memory-ddr4-4400mhz-16gb-8gb-x2.html
4000 MHz –
https://www.thermaltake.com/toughram-xg-rgb-memory-ddr4-4000mhz-16gb-8gb-x2.html
3600 MHz –
https://www.thermaltake.com/toughram-xg-rgb-memory-ddr4-3600mhz-16gb-8gb-x2.htmlProduct video: https://www.youtube.com/watch?v=rg1HCFEFXJk
Buy Links :
4600MHz
TT Premium US –
https://www.ttpremium.com/product/toughram-xg-rgb-memory-ddr4-4600mhz-16gb-8gb-x2/
TT Premium EU – https://ttpremium.eu/product/r016d408gx2-4600c19a/
TT Premium AU – https://ttpremium.com.au/product/r016d408gx2-4600c19a/
TT Premium ASIA –
https://asia.ttpremium.com/product/toughram-xg-rgb-memory-ddr4-4600mhz-16gb-8gb-x2/4,400MHz
TT Premium US –
https://www.ttpremium.com/product/toughram-xg-rgb-memory-ddr4-4400mhz-16gb-8gb-x2/
TT Premium EU – https://ttpremium.eu/product/r016d408gx2-4400c19a/
TT Premium AU – https://ttpremium.com.au/product/r016d408gx2-4400c19a/
TT Premium ASIA –
https://asia.ttpremium.com/product/toughram-xg-rgb-memory-ddr4-4400mhz-16gb-8gb-x2/4,000MHz
TT Premium US –
https://www.ttpremium.com/product/toughram-xg-rgb-memory-ddr4-4000mhz-16gb-8gb-x2/
TT Premium EU – https://ttpremium.eu/product/r016d408gx2-4000c19a/
TT Premium AU – https://ttpremium.com.au/product/r016d408gx2-4000c19a/
TT Premium ASIA –
https://asia.ttpremium.com/product/toughram-xg-rgb-memory-ddr4-4000mhz-16gb-8gb-x2/3,600MHz
TT Premium US –
https://www.ttpremium.com/product/toughram-xg-rgb-memory-ddr4-3600mhz-16gb-8gb-x2/
TT Premium EU – https://ttpremium.eu/product/r016d408gx2-3600c18a/
TT Premium AU – https://ttpremium.com.au/product/r016d408gx2-3600c18a/
TT Premium ASIA –
https://asia.ttpremium.com/product/toughram-xg-rgb-memory-ddr4-3600mhz-16gb-8gb-x2/For more details on TOUGHRAM RGB DDR4 Memory Kit 3600MHz 16GB (8GB x2), please visit :
Metallic Gold –
https://www.thermaltake.com/toughram-rgb-memory-ddr4-3600mhz-16gb-8gb-x2-metallic-gold.htmlBuy Links :
TT Premium US –
https://www.ttpremium.com/product/toughram-rgb-memory-ddr4-3600mhz-16gb-8gb-x2-metallic-gold/
TT Premium EU – https://ttpremium.eu/product/rg26d408gx2-3600c18a/
TT Premium AU – https://ttpremium.com.au/product/rg26d408gx2-3600c18a/
TT Premium ASIA –
https://asia.ttpremium.com/product/toughram-rgb-memory-ddr4-3600mhz-16gb-8gb-x2-metallic-gold/Racing Red –
https://www.thermaltake.com/toughram-rgb-memory-ddr4-3600mhz-16gb-8gb-x2-racing-red.htmlBuy Links :
TT Premium US –
https://www.ttpremium.com/product/toughram-rgb-memory-ddr4-3600mhz-16gb-8gb-x2-racing-red/
TT Premium EU – https://ttpremium.eu/product/rg25d408gx2-3600c18a/
TT Premium AU – https://ttpremium.com.au/product/rg25d408gx2-3600c18a/
TT Premium ASIA –
https://asia.ttpremium.com/product/toughram-rgb-memory-ddr4-3600mhz-16gb-8gb-x2-racing-red/
Recent Articles
- Cooler Master Announces the Case Mod World Series Winners
- Samsung announces the 980 NVMe DRAMless M.2 SSD
- AMD’s 3rd Gen EPYC Processors due to Launch March 15th
1 reply
Loading new replies...
Benching Team Leader
