Table of Contents
Today, July 30th, 2020, Xtreme Performance Gear, a division of Adata, unveiled several new components including power supplies, fans, and RGB light strips. The XPG PYLON power supply is available from 450 Watts up to 750 Watts, followed by a pair of XPG VENTO 120mm fans and an XPG PRIME ARBG LED light strip. Here is the official announcement along with more details for the components.
XPG Unveils New Lineup of PC Components and Accessories for Gamers, Modders, and PC Enthusiasts
New XPG offer includes VENTO series fans, PRIME ARGB LED strip,
and PYLON family of power suppliesTaipei, Taiwan – July 30th , 2020 – XPG, a provider of high-performance products for Gamers, Esports Pros, and Tech Enthusiasts, is pleased to announce a new family of Bronze-certified power supply, PYLON, and an expansion of gaming accessories: VENTO 120 fan, VENTO 120 ARGB fanandPRIME ARBG LED strip.
XPG PYLON Power Supply
Following the heels of the well-received XPG CORE REACTOR power supply, XPG is unveiling the new XPG PYLON to meet the needs of a wider range of users. The XPG PYLON is an 80 Plus Bronze-certified power supply unit with up to 89% conversion efficiency and quality closer to that of Gold level power supplies. It is designed for 24/7 continuous power system operation and comes in four wattage options – 450W, 550W, 650W and 750W – to meet different needs and scenarios. All options feature DC-to-DC circuit 100% +12V. XPG PYLON complies with Intel’s ATX Power Supply Design Guide‘s sleep mode function which makes it future-proof and features a power delivery that remains consistent and efficient, capable of supporting mid to high-end graphic cards and CPUs. Its 120mm Fluid Dynamic Bearing (FDB) fan runs nearly silently at different loads. Combined with its 105°C Japanese Main capacitors (a rarity for this grade of PSUs), the XPG PYLON is whisper-quiet, effici! ent, and designed to last.
XPG VENTO Fans
The XPG VENTO 120 fan and 120 ARGB fan bring exceptional cooling capabilities to any rig without overly distracting fan noise. The fans run up to 1,200 RPM and deliver airflow of 45.3 CFM to guarantee that components stay cool and stable. Sporting rifle bearings, the fans are much quieter than those equipped with standard ball bearings, measuring-in at just 23 decibels. The fans are also designed to last and endure an MTTF of 60,000 hours. For flair in addition to quiet cooling, users can take advantage of the VENTO 120 ARGB fan’s nine LEDs. The LEDs can be controlled through users’ existing RGB control software from most major motherboard makers.
XPG PRIME ARBG LED Strip
The XPG PRIME ARGB LED strip gives modders added flair with ultra-vivid ARGB lighting with eight preset colors and four lighting effects for a total of twelve options. It features SK6812 5050 RGB LEDs for high compatibility with most third-party RGB software from major motherboard manufacturers. For ease of installation, it can be affixed onto a variety of surface types with either high-quality magnets or 3M adhesive strips. It is extensible to cascade up to four lighting strips for a maximum length of 120cm.
Availability
The XPG PRIME ARGB Strip, XPG PYLON Power Supply, and XPG VENTO fans will be available on Amazon and Shop ADATA.
MSRP
- $39.99
- 450W/$69.99
- 550W/$79.99
- 650W/$89.99
- 750W/$99.99
XPG VENTO 120 Fans
- $7.99
XPG VENTO 120 ARGB Fans
- $16.99
About XPG – XTREME PERFORMANCE GEAR
XPG (XTREME PERFORMANCE GEAR) was established by ADATA to provide high-performance products to gamers, esports pros, and tech enthusiasts. We are committed to developing products that deliver extreme performance and therefore work closely with the gaming and esports community to gain insight into the real needs of users. We provide a full range of products from systems, components, peripherals to devices, and create them with the highest standards of stability, reliability, and performance in mind. We also develop products with sheer cool designs that have earned us several prestigious international awards, such as iF Design and Good Design. Beyond products, we play an active role in sponsoring and supporting esports events and teams globally to realize extreme gaming experiences at the highest levels.
Loading new replies...
