- Nov 22, 2001
- UK
I've recently redone my system by making my two radiators run in parallel. The sequence now goes like this;
Pump > Res > Y-splitter...
1. Heatercore > CPU block > pump
2. Radiator > GPU > pump
I've only a little Eheim 1046 pump, and there is alot of tubing and stuff for the water to get through. Water flow seems ok, but it's not brilliant or as fast as it was when I just had one rad and one block.
My thinking so far is that it should be ok. As I see it with my simple logic; as long as there's no real difference between the waterblock temp and radiator temp, then there is no need for faster flow rates. I know higher flow rates mean better heat transfer, but in a closed loop system (such as all watercooling setups) is the flow rate that important?
So basically what I'm asking is; is this pump ok for the job?
Would spending £30 on an Eheim 1048 be worth it.
Also, has anyone upgraded just their pump and seen real benefits?
Thanks in advance for any replies, very much appreciated, thanks!
