- Jan 25, 2001
Okay this is strange... my case has your standard intake front, and exaust back.
When I have intake + exaust temps under load are 51C
when I disconnect the intake, and have JUST the exaust, temps are 49C
This is after ~ 1 hour of prime95
both fans are Sunnon 35cfm fans
Anyone else find this kind of weird? Guess I'll be only running 1 exaust and ditch my intake, no need for extra noise and extra heat. Although I'm worred about the slight negative air pressure within the case. Although my case has vents on the side cover so it should equalize pressure wise w/o having to draw in dust through the CD-ROM etc...
