GuNRocK (Jul 25, 2001 11:17 a.m.):
Sorry guys for my little outburst last night
If a 1Ghz athlon with Coppercore can reach 1.5 or 1.55Ghz how hard is it to believe for a 1ghz duron there allmost idential in cores and now duron 1ghz prerealease is with copper that means it can do those high clock speeds.... and its allittle hint of what the future holds
u will see Duron 1ghz 1.15 1.2 1.25 1.3 1.35 1.4 1.45 1.5 1.55 1.6 if this 1ghz comes out soon....u should see all the way up to 1.6Ghz probly just over 1 year from the realease of the 1ghz.
By the way i think Andy is telling the truth becuase his chip is copper interconenct and that makes allmost anything possible even 1.6Ghz Duron!
Thank you GuNRocK, that is mighty noble of you. It takes a good man to stand up and apologise for his actions.
Don't worry people like "el", "AmbientFiction" and "sfa" who seem to have stood my corner and stated :-
[order=1]
[#]Andy does have means and ways of obtaining something a little newer than shiny.
[#]I have nothing to gain from lying
[#]etc
[/order]
In order to stop any of the criticism that has come my way we need to understand what the chip is:-
[unorder=square]
[#]Morgan Duron is the same to Spifire Duron as Palomino Athlon is to T-Bird Athlon
[#]Although production parts won't perhaps peak to this gravity of speed instantly, engineering samples are made at the best of the process capability window in order to be able to forecast yields for roadmap and economic purposes.
[#]Morgan Durons Core Voltage may well be as low when etched properley as 1.40v, hence why at 1.625v, the engineering sample was able to overclock quite so admirably.
[#]The chip is only with me on a loan basis - with emphasis on it not being publicised on my website. I have to promise not to burn it out or chip the corners of the core during HSF mounting (I might have a problem there!)
[#]Although later Morgans will have copper interconnects like this "Golden Sample" it will be probable that initial chips may be able to use the aluminium interconnect system used extensively on Austin Texas dies. This will be possible because of the difference in design between Morgan and Spitfire, just like there is a difference between Thunderbird and Palomino.
[#]Hence the doubt around the situation probably arises from what people with current Spitfire Durons are acheiving at top end of overclocks which in the general domain is somewhere in the region of 1.02Ghz.
[#]I don't expect to be able to buy a chip that will overclock this far until Q2 2002 - that would make sense. The first Morgans may only go as far as 1.25Ghz as an estimation.
[/unorder]
I hope that this may clarify the situation for some and I hope that any hostility that people are displaying ceases as all that it will serve to do is not good. For me now I am going to concentrate on my dual Via C3 overclocking for a few hours - so I'll catch you all later.
Peace and Love,
