- Mar 11, 2004
- Port Angeles, Washington
Just completed my first volt mod I pulled out my old voodoo3 2000 PCI to see what I could get it up to when I threw some sinks on the ram and a bigger sink on the GPU. Did this and could set to about 192 without artifacting, could only run 3DMark2001 stable bout 183.
Performed a volt mod by modding a 330ohm resistor in parallel to pin 1 and pin 2 on the voltage regulator. Now I can set to 208 and lock up at 209. slight visual artifacting at about 201 mhz.
This is without a bios flash too!
