- Aug 23, 2022
Hi, as my first post ever, I'm gonna try to remain concise because a lot happened. So... to cut through the chase I'm now at 4.4 GHz (CPU ratio only) on my FX-6300 with just the boost voltage and some good LLC (Load-Line Calibration) tuning but as my first committed overclock implies, I'm really not sure how to guarantee stability. Previous mistuning of the LLC to "high" instead of "ultra-high" failed after a long while (I don't recall exactly, 1+ hour ?) the stress test from the latest Prime95 version (30.8).
As I'm trying to figure out if my system is truly stable, I searched a lot for advices on which tests to run and basically came roughly to the same conclusion as this guy but with somewhat different tools (and far less confidence): https://www.overclock.net/threads/stability-testing-in-2019-the-right-way.1722272/
I now have installed OCCT, RealBench, AIDA64 Extreme, CPU-Z, Linpack Xtreme and of course Prime95 ! I genuinely don't recall exactly how much I ran each software on my current config so this is approximate: I did very little of AIDA64 and just minutes of CPU-Z as I don't know how they are supposed to report hardware errors and have been told somewhere they aren't good for the job. I cumulatively ran more than 2 hours of Linpack Xtreme, maybe 2.5 or 3 hours of OCCT in three separate occasions (I think) and maybe a total of 45 minutes of RealBench. OCCT was the one that caught instability at lower voltages iirc (I used it first in most situations). My current 4.4 GHz config passed ALL these stability tests...
... except for ONE ! The latest version of Prime95 crashed with an error reported but only under very dubious and questionable circumstances !
So the first thing I need to explain is before that happened, I noticed something pretty crazy with this version of Prime95 (that turns out to not be the case with the only other version I tried (v28.7) btw): If I select a "custom" stress test and pick a value between 24576 and 24581 MB with a large enough blend of FFT sizes (max can be just below 480K for convenience), any FFT size at or below 160k or so fails immediately ! I didn't check the exact limit though, 256k didn't have this problem iirc. And the best part is that happened to me regardless of the clock settings, it even happened at stock settings with a massive 25 % underclock of the base clock (150 MHz). I don't know what to make of this. Is it my rig that is flawed in an irreparable way or the latest version of Prime95 software that is with this oddly specific amount of RAM. I know that probably sounds like blasphemy to dare question the almighty Prime95 but... Can someone reproduce this problem in his own rig please ?
The second thing that makes me question whether this version of Prime95 found instability in my rig is that the first time I launched it for an overnight stress test. I found out the next morning that the Prime95 software - not the entire OS - crashed but on the washed out Prime95 window, I could see that a single error was reported last. Did it actually found instability or something went completely haywire with the software... again ? So I chose yesterday to search for and download older versions of Prime95 I could find on the web and I ran so many hours of the version 28.7 (from 2015 - 3 years after the release of my CPU in case that's relevant). I can confirm none of the issues I experienced with the newer version happened. I ran version 28.7 for several hours during the day and 9 more hours during the night, no problem, no error reported !
So the million dollars question now is "Is my rig stable enough !?" I'm running it right now with the O.C. in question since the weekend without issues during work days (and play nights in ChilloutVR).
I have some more questions but my post is already enormous as is so let's just focus on the most important for now.
Rig:
AMD FX-6300 @ 4.4+ GHz with no more than 1.4 volt (199.4~202.0 MHz base clock)
Cooled by an OCZ Vendetta 2 (and a gigantic A/C on wheels in the room )
M5A99FX PRO R2.0
4 x 8 GB (Patriot PSD316G1600KH) - And yes, this new RAM completed well over 4 full passes of Memtest86+ flawlessly
2 x AMD Radeon R9 280 (no longer used in crossfire, my current games don't support it anymore )
A Corsair TX750W PSU
P.S. If I should do some O.C. "back off" for stability, what would you experts recommend, -1 % of the base clock or +20 mV on core voltage ? Or both ? Which is better ? I really don't want to age up my CPU too quickly. Also, which one property between voltage and temperature ages the CPU more quickly ?
Rig:
M5A99FX PRO R2.0
